Bogging down when warmed up
Old Jun 21, 2018 | 10:01 PM
Wgoehring3's Avatar
Wgoehring3
1989 ford f350 7.5l bogs down when it gets warmed up and only while I'm driving not at idle. The check engine light flashes rapidly then just stays solid but goes away at idle. It bogs down from 60 to 35 mph as if running out of fuel but then surges back to 60 then does it again. I've replaced fuel pumps and filter, fuel pump relay, fuel regulator, map sensor, took the cat off and still same issue. I have no idea what to do next. The codes that come up dont match the symptoms since it idles fine and will drive fine when it cools down. My codes are in order as follows (97,87,1,32,41,87,95,32,41,87). I'm lost on what to try next. Also the key on the tank pumps are constantly running.
Old Jun 21, 2018 | 10:49 PM
joey2fords's Avatar
joey2fords
a spazzing CEL along with continuously running fuel pumps point squarely at computer trouble.
at the very least you should pull it out and inspect.
many here will say just go ahead and replace the capacitors even if they look ok, and i am inclined to agree with them.
Old Jun 22, 2018 | 06:47 AM
'89F2urd's Avatar
'89F2urd
What joey said. Puter.
Old Jun 25, 2018 | 10:35 PM
Wgoehring3's Avatar
Wgoehring3
1989 ford bogging down.
I switched computers with one from a 1990 and now it surges real bad in idle and driving but no check engine light. I still have the CAT off so I will put that back on.
Old Jun 26, 2018 | 03:19 PM
joey2fords's Avatar
joey2fords
was the 1990 a good running engine or an auto wrecker engine ? if the latter, you may have swapped 1 bad computer for another. these computers worked great for 25-30 years but it is now possibly the number 1 failure point on these trucks.
Old Jun 26, 2018 | 03:42 PM
Wgoehring3's Avatar
Wgoehring3
I'm not sure what running condition it was in but it has a 60 day warranty so I can just go swap it for another
Old Jun 27, 2018 | 08:37 PM
rudifisk's Avatar
rudifisk
Not meaning to hijack this thread, but what does a new aftermarket computer cost for this vehicle? Thanks.
trex1268
2004 - 2008 F150
27
Oct 26, 2014 01:50 PM
quincyj34
Jun 25, 2013 12:20 AM
ford_pickup
Sep 4, 2012 01:02 PM
geodiggr
Jul 29, 2009 05:08 PM
scottalbert06
Aug 5, 2008 08:10 AM
