powered driver seat wont move..Help!!!
Hi all,
I’m new to this forum.
Yesterday when I was moving my driver seat it is stop moving for no reason, it’s been always working well before with no issues in the past. I search around what it could be I have done couple things to solve this issue with no success. Things that I have done-
· Removed seat controller and cleaned, I’ve read that was a problem for many people with the same issue. I know my controller is good because I swapped with passenger seat to test it and it worked. Also I don’t think it’s a motor because my memory seat is working and easy exit option also moves my steering wheel and a seat . Now it’s just stock on the highest setting.
· I check all the connectors made sure that everything is tight.
So far im lost, it’s not a controller not a motor and also memory works so the wiring is fine I also have my cooled and heated seat working. It’s a 10 way adjustable seat.
I will be happy for any advice and help. Thank you.
F150alex6.2 - No I never did I will check it out tomorrow , do you know what fuse is it? and what should I look for ?
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
Dewski
06-25-2017 05:39 PM
Notpilbrisk
1997-2006 Expedition & Navigator
11-30-2005 12:47 AM
