heated steering wheel retrofit!! Success!!
Old Oct 6, 2020 | 08:40 PM
  #46
Marco-Heavy's Avatar
Marco-Heavy
Originally Posted by Alaskan_Warbird
I got all my harnesses from the same guy (to enable heated wheel, as well as make the paddle shifters on the wheel fully functional).
howd it work out for you? Followed same write up?
Old Oct 6, 2020 | 08:55 PM
  #47
Alaskan_Warbird's Avatar
Alaskan_Warbird
In one of the posts on this topic, I posted a bunch of pictures and walkthrough. It went great! I'd do the swap out on my 2019 F450 if there was a Raptor wheel that had Adaptive Steering.
Old Oct 6, 2020 | 09:11 PM
  #48
Marco-Heavy
So quick question I have lane departure, adaptive cruise, I assume I need a wheel with the same features? Also, Someone said the airbag connections are different and the depth?
Sorry for the questions been researching and seeing these questions. I assume this wheel is no good for my optioned truck
https://www.ebay.com/itm/2017-FORD-F...72.m2749.l2649
Old Oct 6, 2020 | 09:27 PM
  #49
jonathanjr1's Avatar
jonathanjr1
you can use just about any wheel, all you have to do swap your existing controls over to the new wheel. I swaped my factory controls to my raptor wheel.
For the airbag connections, it depends on the air bag and the clock spring. I don't know if there were any changes to those components with the newer trucks. i pretty shure the 17‐19 trucks are all compatible with the parts in my Google doc.
Old Oct 7, 2020 | 12:37 AM
  #50
Alaskan_Warbird
Is there a Raptor wheel that has Adaptive Steering? When I did this on my F350 DRW, it was not possible to do the changeout if your truck had Adaptive Steering. This was because there is a little electric motor inside the steering wheel of vehicles with Adaptive Steering.
Old Oct 7, 2020 | 05:44 AM
  #51
Marco-Heavy
this is exactly my concern
Old Nov 24, 2020 | 11:41 PM
  #52
airwalk's Avatar
airwalk
I’ve been considering this for my 2020 F-350, once the harnesses can be confirmed for this year, so this is good info about the steering wheel. I have adaptive cruise, but if I can find a heated wheel without that for cheaper and move the buttons over that would be perfect!
Any chance anyone has come across just the wheel, without the buttons and trim piece?
Old Dec 10, 2020 | 11:28 AM
  #53
Joe_Lee's Avatar
Joe_Lee
Has anyone successfully installed a heated steering wheel on a 2020 yet?
Old Dec 10, 2020 | 12:14 PM
  #54
Ding126's Avatar
Ding126
If you have adaptive steering , then you are out of luck.in regards to a Raptor wheel.
If you want to add a heated steering wheel, 1. you need a new steering wheel with heat. 2 you need a new clock spring that has the connector for heat. I know nothing of the Adaptive steering so I dont know if you can or cant add heat but am thinking heated wheel should be available for that system... Dont mix up adaptive steering with adaptive cruise control. Adaptive steering is the issue for adding a Raptor wheel
If you are paying for a new steering wheel, I would order a Raptor Wheel with heat, new clock spring and a harness from Boosted Gray Goose. It took me less than an hour from start to finish. Could of been quicker but I didnt want to rush and I basically triple checked everything before starting to put things back together.
My truck had a heated wheel previously so all I did was the Raptor wheel with heat and harness from BGG
Old Dec 10, 2020 | 01:22 PM
  #55
Joe_Lee's Avatar
Joe_Lee
Thanks. I like the Raptor wheel but a heated lariat wheel will be fine with me.
Old Dec 10, 2020 | 02:44 PM
  #56
Joe_Lee's Avatar
Joe_Lee
I messaged boostedgreygoosedesigns about the harnesses for the paddle shifters and heated steering wheels being confirmed for 2020 trucks and he replied that they are working on the programming but have not confirmed it yet, but should be soon.
Old Dec 10, 2020 | 03:21 PM
  #57
Marco-Heavy
I have been trying to figure a way to do it for my 20 but no luck so I guess we wait? I have the older boosted harness but assume that won’t work?
Old Dec 10, 2020 | 06:33 PM
  #58
Joe_Lee's Avatar
Joe_Lee
I don't know if the old harness works or not, I'll wait and hope it comes sooner rather than later.
Old Dec 10, 2020 | 06:35 PM
  #59
Ding126's Avatar
Ding126
The harness he provided me was his newest harness on his website for the Raptor wheel..It works perfectly, all paddles work. The controls for cruise and radio/phone were swapped off my lariat wheel and installed on the Raptor.
Wonder what hes working on now??
I may consider selling or trade my 2020 Lariat wheel w/ heat...PM me if interested
Old Dec 10, 2020 | 06:41 PM
  #60
Joe_Lee's Avatar
Joe_Lee
I'm not sure. I asked about the harness for the paddles and the heated steering wheel in the same question, maybe he was just referring to the heated steering wheel harness?
