heated steering wheel retrofit!! Success!! - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 06-20-2018, 03:07 AM
jonathanjr1's Avatar
jonathanjr1
jonathanjr1 is offline
jonathanjr1 is starting off with a positive reputation.
i am in the process of adding the heated steering wheel to my f-250 lariat value package. it look to be very possible just like the f-150 and the fusions by creating a overlay harness. i have the parts on order and downloaded the factory wiring manual. i should be able to enable it with forscan once i get the parts.
the parts i order are
DG9Z-14B561-A - HSWM
CU5Z-14A163-A - Retainer for HSWM - ordered 3
HC3Z-14A664-B - Clock Spring
EU2Z-14474-AA - Terminal BCM - ordered 1
WT-1001 - Terminal SCCM - need 2 (come in packs of 5 used 3 for paddle shifters on raptor steering wheel) received
HL3Z-3600-CA raptor steering wheel with heat - received
WPT-965 - Pigtail HSW received
WPT-955 - Pigtail HSWM received
WPT-977 - Pigtail OBD2 Test Connection received
Write up
https://docs.google.com/document/d/15IW-hv1rVLkygN8qvvM45UjENexfbtMCr3NNv2uWrzw/edit?usp=sharing
Old 06-22-2018, 09:58 PM
jonathanjr1
Made some progress today i completed the harness. I'm still waiting for my clockspring and hswm.
Old 06-23-2018, 09:48 AM
CO Wapiti's Avatar
CO Wapiti
CO Wapiti is offline
CO Wapiti is starting off with a positive reputation.
You should add the paddle shifters as well since you have the Rapter steering wheel !!!!!!
Old 06-23-2018, 11:09 AM
wrvond's Avatar
wrvond
wrvond is offline
wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.
Interesting. What does the Raptor steering wheel look like?
Old 06-23-2018, 05:32 PM
jonathanjr1
i already got the paddle shifters working I'll post a vid of them working and some pictures in a bit. There another thead about the swap.
Old 06-23-2018, 06:29 PM
jonathanjr1
Old 06-23-2018, 06:46 PM
CO Wapiti's Avatar
CO Wapiti
I canít wait to see your installation and video for the paddle shifters. I manually shift all of the time while towing and it would be hard to find a worse place to put the current rocker switch. Paddle shifters would make it SO much easier (and safer, for that matter). I will search the thread again and watch for it.
Old 06-23-2018, 09:29 PM
wrvond's Avatar
wrvond
wrvond is offline
Originally Posted by jonathanjr1 View Post
Interesting. Thanks for posting that. Our Lincoln has a heated steering wheel with shift paddles. Other than trying them out, I never use the paddles myself, though I could see using them while towing. The heated steering wheel, on the other hand, is a very nice option that I wish my truck had.
Did you come up with a total cost for the conversion?
Old 06-24-2018, 08:35 AM
jonathanjr1
so far i'm in about $670 with the raptor steering wheel, the raptor steering wheel was $390 of that. the standard leather wrapped or king ranch steering wheel could be done for just under $500. i will post my google doc once i get every thing done.
Old 06-24-2018, 12:03 PM
wrvond's Avatar
wrvond
wrvond is offline
Very good to know, thanks. The standard leather wrapped steering wheel appeals to me more than the other options. I thought my truck came with a leather wrapped steering wheel to begin with, though...
Old 06-24-2018, 05:29 PM
jonathanjr1
It does but there are different versions of steering wheel. The lariat value wheel doesn't have the heating elements and thermistor built in.
Old 06-25-2018, 12:03 AM
Txfoster
Txfoster is offline
Txfoster is starting off with a positive reputation.
Subscribed!
Old 06-25-2018, 06:32 AM
Gwilkrrs
Gwilkrrs is offline
Gwilkrrs is gaining momentum as a positive member of FTE.Gwilkrrs is gaining momentum as a positive member of FTE.
interested as well!!
Old 06-25-2018, 07:50 AM
WVSD's Avatar
WVSD
WVSD is offline
WVSD is starting off with a positive reputation.
Subscribed
Old 06-25-2018, 12:47 PM
LaxPlaya21's Avatar
LaxPlaya21
LaxPlaya21 is offline
LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.
This is awesome stuff! I don't understand why they didn't offer the paddle shifter for our steering wheels if they offer a manual mode. It is pretty silly having to use the plus minus on the gear lever.
Quick Reply: heated steering wheel retrofit!! Success!!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
