1991 F250 351w losing all electrical power when I turn the key.
Old 06-19-2018, 05:11 PM
EOMFD's Avatar
EOMFD
EOMFD is offline
I have a brand new battery fully charged and I've load tested it twice now but the truck is still acting like it has a dead battery. Every time I try to start it I get a click from the starter and everything goes dead, dome light and all. Everything stays dead until I disconnect and reconnect the battery. Any ideas?
Old 06-19-2018, 08:16 PM
HardScrabble's Avatar
HardScrabble
HardScrabble is offline
Temporarily Deactivated
My guess would be a bad battery terminal connection or a wire connection real close to it. Maybe try headlights and/or brake lights next time it goes out. Safety equipment is more directly wired. If you have a meter you can check where you have power and don't have power.
Old 06-21-2018, 12:48 AM
GiggityBurns's Avatar
GiggityBurns
GiggityBurns is offline
I'd guess corrosion on wires, most likely bad ground
Curtis_v
16
08-06-2017 02:25 PM
JJray
36
01-16-2012 10:04 PM
Edgethis
16
02-03-2011 06:40 PM
FordGuy91
11-17-2010 04:42 PM
TIMG1450
1997 - 2003 F150
10-29-2005 11:33 PM
Quick Reply: 1991 F250 351w losing all electrical power when I turn the key.
