AMP Automatic Step clicking noise
Old Jun 18, 2018 | 12:50 PM
jjwm76's Avatar
jjwm76
Have a 2018 F250 with auto side step from AMP. When the driver side step comes down or goes back up it makes a clicking sound. The passenger side doesn't make a sound. Has anyone else had this issue? Thanks, Jason
Old Jun 18, 2018 | 12:57 PM
WVSD's Avatar
WVSD
Mine is exact same way.
Old Jun 18, 2018 | 01:24 PM
jakematic's Avatar
jakematic
Is there any dirt / grit / etc in the mechanism ?
AMP Power Step maint
Old Jun 18, 2018 | 06:39 PM
MDK123's Avatar
MDK123
Mine too - em brake cable. Move it out of the way and it’ll stop.
Old Jun 18, 2018 | 10:45 PM
brandon4's Avatar
brandon4
Came with a bracket to relocate brake cable . Never put mine on .
Click...
Click
Click
Old Jun 19, 2018 | 07:44 AM
jakematic's Avatar
jakematic
Interesting.... was no brake cable re-location bracket on my 17, and don't recall it being an issue when I installed it.
Will have to get under the truck and check it out. Not clicking but need to check all the fasteners anyway.
Old Jun 19, 2018 | 09:29 AM
super_duty_532's Avatar
super_duty_532
I just installed it on my 18. No relocation brackets in the package. No click sound.
Old Apr 14, 2022 | 11:28 AM
spoony's Avatar
spoony
Resolved…for me
After months of trying to get it resolved on my own and with a tech, I finally got someone from Amp-Research that knows what to do.
Here is the entire response in an email.
I used a mallet to smack the gold bolt at the back of the linkage after loosening and you can actually feel it wiggle a bit.
See below:
​​​​​​​Thank you for reaching out to AMP Research Technical Support team. This sounds like a bolt and wedge adjustment needs to be performed. Please follow the steps below.
Bolt and Wedge Adjustment
It sounds like the bolt and wedge on the linkage needs to be adjusted. To adjust the bolt and wedge you will need to remove the motor on that drive side and allow the board to deploy down. While the board is deployed loosen the one gold bolt that is located on the back side of that front linkage arm to being finger tight. After which please have someone apply light pressure onto the board and smack the bolt once, then tighten that same bolt all while someone is applying light pressure on the board.
Regards,
Robert F.
AMP Research Customer Service
acm05fsu
13
Apr 14, 2007 12:23 PM
Bargod
Sep 26, 2003 04:08 AM
scootin
Aug 28, 2002 10:12 PM
dave186
Dec 27, 2000 10:07 AM
