Steering parts
Old Jun 16, 2018 | 12:20 PM
F100-1969's Avatar
F100-1969
Steering parts
Does anyone know if the drag link, center link, and inner tie rods are the same for 67-72 and 73-79? When I bought my truck he had already changed to power steering and disc brakes from a 78-79 truck so I am wanting to change out those parts because they are very worn out. I can’t seem to see a difference so I wanted to be sure on which year to buy. All of those parts should have been swapped out from the 69 to 78/79 to make the power steering work correct?
I have a 1969 2wd.
Old Jun 16, 2018 | 03:17 PM
ultraranger's Avatar
ultraranger
I have a 1969 2wd.
In the interest of eliminating any fitment problems, it would be best to order all the steering linkage parts for the year model of the donor truck parts.
The front disc brake suspension I put on my '69 F100 came off of a '77 F100 donor truck. I ordered new Moog kingpin set and steering linkage components for a '77 F100 and everything fit like it should.
Old Jun 16, 2018 | 06:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I have a 1969 2wd.
Draglink: 1965/70 F100/250 2WD is the same, ditto 1971 before serial number M00,001. 1971 F100 2WD from serial number M00,001, 1972 F100 is different as is 1973/79 F100 2WD & 1975/79 F150 2WD
Left tie rod, right tie rod end same: 1965/70 F100 2WD, some 1971 F100 2WD. 1972 right tie rod end same, but 1973/79 F100 2WD, 1975/79 F150 2WD left tie rod, right tie rod end are different.
hwcasey12
Aug 16, 2010 02:23 PM
yellow truck
Mar 3, 2009 11:56 PM
bfgfocus
Jan 19, 2005 06:28 PM
fordboy390
Oct 8, 2003 07:00 PM
