Box compatibility?
Old Jun 15, 2018 | 02:56 PM
Motolover's Avatar
Motolover
Box compatibility?
I have come across a box off a 1953 ford f100 and I was wondering if it would fit my 1950 ford f1? Any input is appreciated.
Old Jun 15, 2018 | 03:28 PM
56panelford's Avatar
56panelford
I don't see why it wouldn't fit and bolt right up to the frame but you'll have to use the 53 and up fenders so they won't match the fronts..
Old Jun 15, 2018 | 08:05 PM
52 Merc's Avatar
52 Merc
As John said, the box will bolt up fine. It's essentially the same box that was used from late 1950 on. The problem you'll run into is the studs for the fenders that are welded to the box sides won't be the correct pattern to fit your '50 fenders. The later fenders look really goofy on the earlier trucks, and they won't fit at the running boards. You'll also likely make a really big mess of things if you try to remove the studs and replace them in the early pattern. They don't come out easy and you'll do big time harm to the sheet metal by the time you do. Best to wait and find an early bed, or buy a repro. That's my input.
Old Jun 15, 2018 | 08:33 PM
Motolover's Avatar
Motolover
You guys confirmed my suspicions, I'll just fix up the one I have, thank you for your help.
1949fordf3
Jan 31, 2009 10:45 PM
Arrow201
Feb 10, 2008 07:42 AM
gingerbreadmaniac
Sep 9, 2002 11:47 PM
selbyrk
Jun 19, 2002 03:06 AM
