Not overly impressed.
Old Jun 15, 2018 | 07:35 PM
  #31
Msmith1968's Avatar
Msmith1968
I really don’t need to go faster than 60-65. Not a speed demon.
Old Jun 15, 2018 | 07:46 PM
  #32
Raptor Rob's Avatar
Raptor Rob
Ok this may sound silly, but are Your gas pedal adjusted properly. Like I said it sounds silly, but if Your not pushing the gas pedal all the way down, your going to notice a performance drop. I speak from experience. lol
Old Jun 15, 2018 | 07:51 PM
  #33
Msmith1968's Avatar
Msmith1968
Believe me i was standing on top of it. “Where’s the power”. Lol
Old Jun 15, 2018 | 09:47 PM
  #34
mothnuts's Avatar
mothnuts
Might try adjusting the pedals closer to you. It might be a long shot, but I found it to be the problem on my ‘16 Denali HD. I’m 6’3 and had moved the pedals further out to give me more leg room. One day someone else had adjusted them closer to the seat and it was like driving an entirely different pickup when I got back in. I haven’t had this problem with my F250, but might be something to try.
Old Jun 15, 2018 | 09:51 PM
  #35
Msmith1968's Avatar
Msmith1968
I’d agree but i was in cruise control in addition to pushing the peddle as far down as possible. Literally “standing” on it. I assure you i was to the floor.
Old Jun 16, 2018 | 12:32 AM
  #36
flanneljunkie's Avatar
flanneljunkie
Originally Posted by 2009kr
Doing a quick calculation, your 4th gear with 34" tires and a 3.55 is nearly identical to my F450's 5th gear with my 4.30 and 31.5" tires. I pull at around 2570 RPMs at 65 in 5th, so you should be around 2630 at 65 in fourth. You should have no issue pulling 6% grade at 65 in 4th gear, 2630 is a fine speed for the 6.7.
This was exactly my experience with my driving partner on our trip. He had an f450 and always ran one gear higher than myself. Not saying that running one gear lower is bad, I just didn't much care for the pulling experience while in auto. Also, one instance of the f450 kicking my but with the much smaller turning radius. It was a very tight fuel stop in a congested city.
Old Jun 16, 2018 | 01:01 AM
  #37
briangp's Avatar
briangp
Subbed out of curiosity. Something doesn't sound right here....
You can always manual mode your gears you know?
Old Jun 16, 2018 | 06:31 AM
  #38
Cabindweller's Avatar
Cabindweller
You should take this question seriously. I’ve seen cases where the power adjustable pedals were adjusted low (close to the floor) resulting in the driver not being able to give the truck enough throttle to perform properly. It sounds silly but has happened. Do yourself a favor and look into it.
I’ve pulled that same exact mountain pass with my 13,000 pound fifth wheel in tow and cruised right up it at 60mph, no problem. No weird downshifting either. I was super impressed, comparing to the performance of my former Ram 3500 diesel. My truck is the diesel with the 3.55s.
Old Jun 16, 2018 | 06:48 AM
  #39
harmanrk's Avatar
harmanrk
Another thing to keep in mind as this is a SRW truck we are talking about, is once it drops to 3rd, getting back to 4th on the grade may not be possible due to the torque management, for 1st - 3rd on the SRW trucks. If you did not have enough torque to hold 4th, and the computer drops to 3rd, but the engine management system does not allow you as much torque in 3rd as you had if 4th to begin with.
Old Jun 16, 2018 | 08:28 AM
  #40
Msmith1968's Avatar
Msmith1968
Originally Posted by stufarmer
I'd go back to your GMC
smart a** comment.
Old Jun 16, 2018 | 08:42 AM
  #41
senix's Avatar
senix
Lets all play nice, I do think there is more to the story here, but not the op, rather how the truck responds vs the GMC.
There maybe a issue with the go pedal and its location or just gearing.
Old Jun 16, 2018 | 08:49 AM
  #42
Msmith1968's Avatar
Msmith1968
Will find out Monday. Pulling it back the same road. I plan to lock out 6th gear up all these hills and start up the hill with good momentum so it doesn’t try to gear down to third. It just may be a different way of gearing the truck vs the GMC which had 3.73. Also hoping the wind won’t be blowing like the other day.
Old Jun 16, 2018 | 10:25 AM
  #43
Mxsledder's Avatar
Mxsledder
With your old GMC being a 2016 (non L5p) your new truck should be able to out pull it no problems at all. From what I’ve read I think it’s possible you just had a really bad head wind.
Old Jun 16, 2018 | 10:46 AM
  #44
hookd's Avatar
hookd
We have a 2014 CCSB F350 6.7 with 3.55 gears and have not been overly impressed with the mountain towing. When we bought it new we had a 8k (empty) travel trailer and pulling in the mountains of Colorado Wyoming and Montana was great. This year we upgraded to a 12k (empty) fifth wheel toy hauler and it seems to hunt gears even on small hills. We are looking at ordering a 2019 with 4.30 gears since it is not a daily driver and is mostly used to tow. I love this motor but hind sight being what it is I wish I would have done more homework on gear ratios. We are not just upgrading because of the gearing we also want to get a long bed and the upgraded technology so it's paid off when we are ready to retire. Live and learn I guess, good luck with yours.
Old Jun 18, 2018 | 04:51 AM
  #45
fskubota's Avatar
fskubota
Spot on hookd, gearing has a LOT to do with pulling, look at ordering, the bigger the truck, the lower the gearing ratio you can order with the truck. had an 07 duramax, 3:73, when pulling, i had to use the manual shift or it would over heat, it takes a lot more torque and power to turn a higher gear ratio. higher gear ratios are for crusing, lower ratios are for pulling!!!!!
