Sponsored by: Auxito
Auto to manual ?
Old Jun 13, 2018 | 08:12 PM
Mickey Bitsko's Avatar
Mickey Bitsko
Auto to manual ?
This might be a odd question, if I was to change my transmission from 4r70 to a zf5, first, is it possible without a bunch of computer issues, second, will I be getting a stronger tow vehicle?
thank you.
Old Jun 14, 2018 | 02:29 AM
Bluegrass 7's Avatar
Bluegrass 7
The computer shifts the automatic.
It looks for the circuits to be their, if not a lot of codes will be set.
A manual uses a different computer program, needs a clutch pedal assembly and associated switches.
Trans mounting, drive shaft etc. all need to be addressed..
Not a worth while change over for all the hassle and expense..
Old Jun 14, 2018 | 06:48 AM
Mickey Bitsko
Thanks Bluegrass, I had no idea manual transmissions have ties to computers to operate. I posted same question on another site, it was suggested I can build my 4r70 to handle quite a bit of torque cheaper than going through the headache of changing to a manual. I'm not planning to build my 5.4 2v any more than mild upgrade when the time comes .
I don't have doubts in the towing capability of my 150 but it's being recommended I move up to a 250. I think many people under estimate the 150 imho.
I followed your lead installing a fan on the trans cooler, next is installing one on the radiator, so far so good. Thanks again.
Old Jun 14, 2018 | 09:26 AM
jughead808's Avatar
jughead808
Take me a look at this, it’s BCA Transmission
​​​​​​​Home
Old Jun 14, 2018 | 09:30 AM
Bluegrass 7
A trans shop that specializes in building high performance transmissions can do the 4R70 or any auto you have..
There are at least three grades of friction materials to use depending on the application to as far as high horse power drag racing.
Improved front pump, bearings, improved EPC , custom converter and valve body changes. Smooth positive gear changes..
After a build like this, Mercon V is no longer used as a fluid but may be Ford LV as in my build or the fluid they want used in the build..
For towing the rear gear ratio accounts for quite a bit..
The shop I use can even make changes to the computer operating program to compliment the result..
The cost is a bit steep but you get first class results by the owner who has been in biz more than 50 years and does world wide Biz..
If you were to drive my 4.6L from a stop you might not believe the motor is stock, but the trans has had the magic touch.
The shop is LEVEL, 10 Hamburg, N.J.. If your interested , .give them a call and talk it over.
Good luck..
Old Jun 15, 2018 | 06:22 AM
Mickey Bitsko
Thanks for the replies, I will give both shops a call, I'd love to keep my auto and I darn sure don't need a 250.
Patrick R.
General Automotive Discussion
45
Feb 22, 2016 01:50 PM
edtahaney
43
Feb 20, 2016 09:11 AM
BigHazard
Nov 14, 2015 01:30 AM
Larry1981
Apr 26, 2007 09:02 PM
elliott
Jul 1, 2001 08:38 PM
