239 Flathead Flush
Old 06-13-2018, 05:00 PM
Old51f3's Avatar
Old51f3
Old51f3 is offline
239 Flathead Flush
Can someone give me some advice.
Im installing a new CHAMPION 3 Row radiator on my 1951 ford F3 when I removed the origional one I noticed some old sludge on the 2 bottom outlets I wasn’t planning on getting my motor rebuild just yet. So my question is
what is the meat way to flush out all that old sludge before I put In my new radiator ?
Old 06-13-2018, 05:08 PM
Hotrod350's Avatar
Hotrod350
Hotrod350 is offline
Garden hose attached to the upper radiator engine mount. Will want to capture the first few gallons as it will be contaminated with antifreeze but after that it should be water/sludge. Alternatively, if you don't like the sounds of running water, you could fill it and drain it a couple of times to move the sludge out.
Old 06-13-2018, 10:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
The engines in all these old Fords are sloped to the rear, and the flat V8's don't have any drain ***** at the back of the block. So draining the coolant doesn't really drain the whole block.
If you can park the truck facing downhill safely (wheels chocked, in gear, e-brake on), it really helps to flush from each thermostat hole on the heads, with the lower radiator hoses off. That said, the sludge that builds up in the lower back of the block is famous for being hard to get out without having the heads off, but it's the best you can do.
Old 06-13-2018, 10:37 PM
Old51f3's Avatar
Old51f3
Old51f3 is offline
Thank you guys
yaaa I did doit outside my driveway. Has a little incline. Worked awesome ..
Old 06-14-2018, 08:02 AM
big job's Avatar
big job
big job is offline
Be creative make a adaptor for the bottom hose for your garden hose maybe plastic with a tapped hole for shop
air. Run the water and short burst of air this is reverse flushing : watch out for years of junk comming out of the
head outlet. Same with radiator bottom hose and blast it. My bought new by my father 50 F6 now steaming and blowing its load caused from years and yrs of stop leak and whatever -block was half full of that junk. The
thought was stop leak for another days work. The engine back when, was Cody Ford Summerville Ma short block. still runs perfectly...
Old 06-14-2018, 11:38 AM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Scotty's 52 F3 is offline
BEFORE I changed my radiator, I flushed with straight phosphoric acid. Then pulled pumps, had engine on down hill slope and blasted with pressure washer. Also took out T stats and blew into heads. Looks like new inside and no overheating here in AZ. I posted all this up. Id do a link if I ever remember how.
finitetime
08-21-2012 10:44 PM
charlescc
1999 to 2016 Super Duty
03-15-2011 09:45 PM
00 Nav
1997-2006 Expedition & Navigator
01-02-2010 03:25 AM
brooklyn
12-21-2008 03:27 PM
dcdave
13
01-20-2004 02:12 PM
Quick Reply: 239 Flathead Flush
