I don't know if you are looking for the ones at the end of the springs like pirate showed which are usually called tip inserts, or the rectangular isolator pads between the springs. I believe it is the F series that have steel pads between each leaf and the Excursion uses plastic ones.
When I installed my V and B code springs I replaced the old tip inserts, I bought them years ago from ATS . They are still around and sell them HERE. There are 3 pages of tip inserts of all shapes.
As far as the rectangular isolators between the springs, I just made my own. I ordered a Teflon sheet of the right thickness online and cut and drilled it. .. Made all I needed cheap from that sheet. You can also use Delrin sheets if you want. but they will wear faster.
