I need help?
Old Jun 12, 2018 | 06:52 PM
Bigjohn1973's Avatar
Bigjohn1973
Thumbs up I need help?
ok I have a 64 f100 sort wheelbase I want to put a v8 in it.i have a 1993f150 with a 302 and auto trans. What I’m asking is can i swap out the tbi to carburetor and it work fine ????
In order to be able to post messages on the Ford Mustang Forums : Corral.net Mustang Forum forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
Old Jun 12, 2018 | 10:03 PM
James_Western_Canada's Avatar
John: Yes, the EFI engine can be retrofitted with a carb, but there are a few things to be done along the way....
If you're leaving all the front serpentine drive accessories as they are, your'e fine, but if you go back to an old style V belt setup, you'll need to change out the reverse rotation water pump used with serpentine drive for a conventional style water pump, and while you're at it, if you are planning on running a mechanical fuel pump, the timing cover will need to be changed to one that allows for a mech pump, and this will also require you to add the eccentric that drives the mech pump. (It bolts to the cam). If you stay with serpentine drive and elect to use an electric fuel pump, you don't have to mess with any of the front stuff
Here is a bit of info on which cover goes with which pump, etc
http://www.hotrod.com/articles/pit-s...p-interchange/
The EFI distributor will not work on a carb'd engine, as the ECM controlled timing, advance, etc...
I'm not sure if the 302 in trucks was hydraulic roller cam or not? The Hyd roller cams require a specific type of drive gear, so If yes, you can use a 1985 Mustang. 5.0L Carb'd distributor. If not hyd roller, any pre EFI distributor will work.
Any 302/5.0 from 1981 and newer will use a 50oz imbalance flexplate or flywheel, so keep that in mind when you're getting to the point of adding a trans....
That's the short version, if you have questions, fire away!!
**Forgot to mention, since you truck was never available with SBF in it, you will need to fab engine mounts, here is a link to one setup, that is available from Speedway, Transdapt, and a host of others....and there are also several other styles of mounts. They're out there, all you have to do is choose...
https://www.speedwaymotors.com/Speed...ount,3274.html
James
PierceEye
Engine Swaps
13
May 30, 2007 02:45 PM
darrin1999
Oct 4, 2006 08:40 AM
61UniB100
Apr 4, 2006 11:40 PM
black58
29
Apr 2, 2006 08:25 PM
1yamman350
Feb 6, 2005 02:24 AM
