The previous owner stripped out the threads on the intake where the AiH goes. My mechanic pulled it and put oil resistant rtv. When it was leaking again 40 k miles later I bought the riff raff delete plug. It just barely grabs the threads but backs out. Can I have this welded in place or does anyone have a solution.
thanks
I dont see why you couldn't get it welded in place. Someone with good TIG skills would make short work of it. Just keep in mind...no going back without buying another tube.
Thanks for the replies I’m thinking trying the jb weld for a temp solution before an up comming long cruise. Seems it really needs something to stop it from backing out instead of blowing out. If that dosent work I’m going to probably have it welded. The set up is the afermarket 2 piece spyder and I don’t plan on ever changing it. Additionally looking to add a boost gauge on to the aih delete plug. If I had the tools on hand I would have already done a set up like 350 suggested and tap the new plug always feels good when a repair beefs up a part.
IIRC Permatex makes a thread 'repair' putty, use to sell it to a couple customers that stripped carbs out back in my parts days - could give it a go if you find it local.
This is what I was referring too. Remove your plug, measure I.D. order a female threaded weld in bung that fits in the current bung, buy appropriate plug for new bung. Then you still have the ability to use the fitting down the road.
As mentioned above it will most likely be a problem with smog. Even though there are a few parameters required before the AIH even activates it is a smog related issue.
I’m hitting the machine shop in the morning they said they can weld it quickly. The truck is it in CA and don’t feel like spending the time sealing this one as the welding should be one and done while retaining the boot gauge fitting.
