Carb to efi
Old Jun 11, 2018 | 12:52 PM
Brad Messenger's Avatar
Brad Messenger
Carb to efi
1986 ford f250 460 7.5 carb to efi how to
Old Jun 11, 2018 | 02:32 PM
Conanski's Avatar
Conanski
Get yourself a donor vehicle.. ideally an early 7.5 truck without a computer controlled trans so '88-90 I believe and transplant the whole topend of the motor(heads, intake, distributor) all engine wiring and computer, and the whole fuel system.. tanks, lines and pumps (where applicable), no external(frame mounted) fuel pumps on '90+ pickups.
Old Jun 11, 2018 | 08:08 PM
FuzzFace2's Avatar
FuzzFace2
That is a hard way to do that in my book.
Check out Summit Racing for bolt on EFI.
FAST EZ EFI systems
Electronic Fuel Injection Leader - FAST® - Fuel Air Spark Technology Fuelairspark.com
http://www.diyautotune.com/
Affordable Fuel Injection
http://fitechefi.com/
Dave ----
Old Jun 12, 2018 | 09:28 PM
jackietreehorn's Avatar
jackietreehorn
3 ways I can think of:
1. 96 or 97 the 460 got MAF. Best year to get. Really, you'd be looking at swapping engine and trans to keep the computer operating properly or get the older model as mentioned. Going that route, It honestly might be easier to put your truck body on a 90's frame with the injection already there.
2. Swap late 80's-91 ford 460 heads and EFI.
3. Cheapest and easiest way is probably to adapt GM TBI from 80s to mid 90s. The expensive Holley aftermarket kit is basically this.
Old Jun 13, 2018 | 07:39 PM
cadunkle's Avatar
cadunkle
If you're doing EFI there's no point in those aftermarket TBI systems, they're no better than a carb. You'll still have the same uneven fuel distribution issues inherent in any wet intake. They're terribly expensive for zero gain over a decent carburetor. Converting to EFI is a great way to lighten your wallet, but if you go that route do MPI.
Old Jun 13, 2018 | 07:45 PM
jackietreehorn
Wasn't Ford's OEM EFI on the 460 technically TBI right up to the end?
Old Jun 13, 2018 | 07:59 PM
Franklin2's Avatar
Franklin2
The wiring diagrams show 8 separate injectors for the 460.
SlikWillie
May 20, 2019 08:56 AM
mltdwn12
Oct 22, 2014 04:49 PM
xavier23
15
Jan 8, 2013 02:29 PM
burge743
16
Jun 10, 2008 04:16 PM
onetonford
Jul 5, 2003 11:11 PM
