Many times, folks like me are then called "The Weight Police"
Wear it like a badge of honor. Seriously, your advice may influence more than just the OP that you're responding to and you may very well save someone from being injured.
We need a Weight Police badge. LOL!
I've got one over on the IRV2 forum...LOL! And honestly, I'm not offended by it. I've got a degree in "Hard lessons Learned" as a result of buying a truck that I thought I could tow almost anything I wanted...RV-wise, then 6 years later trying to buy that RV and finding out that the truck I had bought wasn't close to being big enough for it.
Got a link to the badge? I would like to see that. I'm on IRV2 as user HighPlainsRV, but I don't post there much. I find the RV/towing forums here are better.
I'm all for watching specs like payload so long as the means of satisfying a spec doesn't put people in an unsafe scenario. It's very easy to mind all the specs in the book and on the door and still be unsafe. For instance, I'd much rather be 500 lbs over on payload (5% of the GVWR on a F250) then balance a trailer like a teeter totter just to keep a truck in payload compliance. It's technically right and yet unsafe at the same time. That's my only beef with the "weight police"...sometimes strict adherence to a spec results in poor advice.
Someone in one of these threads mentioned using sand bags and dumbbells to stabilize a bumper hitch trailer. At that point, it's a good time to step back and analyze what's going on before going any farther.
I would be the guy that has two 60 lbs sandbags and one 35 lb barbell weight plate in the front of my T.H. to add some weight in the front. I don't remember the specific post, as I recall, explained the reasoning for adding some weight up there. Heavy loading in the rear of the T.H. (two motorcycles, paddock stands, paint buckets filled with concrete for weights for the pop up canopy, canopy, rollaround tool box, spare set of tires and wheels, 30 gallons of gasoline in the toy tank, etc. When everything was loaded, the TH barely had 10% of the trailer weight on the tongue and I was having swaying issues.....really bad swaying issues, and that was at 50 mph......so in my opinion, not enough tongue weight is what was going on! I now am at about 11.5% of the trailer weight on the tongue and it tows fine.....
Umm what senix reccomended IS how it’s done in real life.... in the eyes of DOT.
Your calculations are also not even close to values shown by Ford either.
I don’t mean to be rude but let’s be serious for 5 mins...2800 lbs of pin weight is peanuts. Definitely not 450 territory unless you have cash to burn on fuel tires and truck. If it makes you feel better then why did you stop at a F450? I mean there are plenty good semi tractors out there.
Your cash, your choices, I get it.
I used to have a ‘12 F250 6.7 with air bags and upgraded shocks. I never ever had trouble with my 35’ Fiver with a pin of 2500 lbs.
you listen to the WP on the forums and you’d think I’d been killing baby seals or something.
I just came back from a camping trip in which I saw at least 4 F250’s pulling triple axel toyhaulers w/o any problems. They were definately over the advertised payload, but not a one of them were over the axel rating.
For the OP, Senixs advice is the most relevant. If I were in your shoes I’d worry the most about the axel / tire ratings and move on with life.
My numbers are correct. Note that in my post above, I gave the payload remaining after adding 350# of passengers and a 150# hitch to a upper trim SRW truck.
Here are some real world data with my 2800# "peanuts" pin weight. With a 1000# lighter SRW, I'd have 12,480# on the truck instead of the 13480# shown on my F450. That's 980# over for an F350, or 2480# over for an F250! The numbers don't lie. Keep in mind, the advertised weight of my trailer is 13.7k with a 1740# pin - advertised weights are without options like a 2nd AC, or water.
If I stay within the limits set by teams of highly trained experts (Ford) with lots of modeling and testing, I need a DRW. If some want to listen to various folks on the Internet using examples of overloaded rigs as proof that a proper truck is just to "feel better," well then that's up to the reader.
Given that arguments about weight ratings seem ubiquitous in so many websites, I often wonder if anyone ever changes their position. I'm pretty simple about these things (or maybe I'm just simple ), but the only weights I trust are the ones from a CAT scale and the ones on my door sticker. Have heard all the arguments for and against countless times, but they just seem to make my head hurt and I don't like my head to hurt.
Well, I changed my position. Actually, it wasn't so much a change of position as a dose of reality when I went to the CAT scales and realized that I was overloaded with my F250 and the T.H. that I had. My change of position, so to speak, was accepting the fact that I was overloaded and needed a different truck to be able to tow what I had both safely and within the weight capacities of the truck. Now some would argue that I went overboard when I bought a F350 CrewCab Dually.....and I did. I could have pretty easily gotten by with a SRW F350 for the trailer that I have and it would have worked just fine......but (and there's always a "but"), since I was changing trucks, why not go with a Dually for even more stability...AND....to have a truck that would be able to handle an even larger trailer if I decide to go bigger in the future. So now, I have the same 13K GVWR trailer, but the truck that I have is more than capable for a much larger 5ver if and when I want to do something different. Payload on this truck is at 5270 lb and I have approx 600 lbs in the bed of it with a full aux. tank of diesel and the toolbox. That still leaves me with almost 4700 lbs of payload capacity for a larger 5ver. Excess payload capacity is a wonderful thing!
I meant more like changed their mind based on a "discussion" in a forum. I understand what you did. I have my empty truck weight, the weight with our fiver on the back, and a weight with our truck camper in the bed and I know what my sticker says. Like I said, too much thinking hurts my head.
I have a 350 SRW .I put F rated tires on it and air bags. The tires are what limit the load. I gained about 600 lb by putting on the F rated tires. I have had 2 Dully wheel trucks before. Just do not like not being able to go through some drive through lanes or car wash. ITS just a better fit for me. 3200 lb door sticker. Weight my 5th wheel at cat scale just under 2500 lb pin weight. Loaded up with me in it no better have in truck. 30 years driving over the road car hauler. Retired. 2017 3500 SRW CC 4X4 Lariat. Montana 3121RL Legacy. Pulled the great.
I'm with you. It's much easier to simply compare the CAT weights to the door sticker values. I believe it may even be simple enough that a jury of my peers could figure it out. I don't want to experience the thrill of trying to sell "A + springs = B" logic to a jury or judge.
So you've got a 5ver that has a GVWR of approx 16,300 lbs with a pin weight of 2500 lbs. Something sounds wrong there. The advertised empty weight of that trailer is right at 12,000 lbs....which would put your pin in the 2400 lbs range. Do you tow it empty...with nothing in it?
... The tires are what limit the load. I gained about 600 lb by putting on the F rated tires...
There is some dangerous advice on this forum. The tires are part of the system that limits the load. The 6 tires that came on my F450 are rated for 22,940#, my truck is rated for 14,000#. My springs, steering, etc. limit my payload, not my tires. The engineering that goes into setting the payload is complex, not just a single variable.
On trucks limited by their class (e.g. 10k F250, 14k DRW), there is likely some additional margin, but you are really guessing about safety with very little data.
