Hub centric rings
Old Jun 10, 2018 | 11:57 PM
6door74's Avatar
6door74
Hub centric rings
Hello all,
I'm awaiting a set of tires to install the Pro Comp 1069 wheels on my 2006 E350. The center bore om the van is 123.9 and the diameter on the wheel is 130.81. Can anyone advise where i can hubcentric rings that big? So far i haven't had any luck.
Thanks
Old Jun 11, 2018 | 08:52 AM
GreeVan's Avatar
GreeVan
If the wheels use acorn type of lug nuts, you do not need the hubcentric rings. The taper of the nuts will center the wheel as you tighten them in the proper star patter. The ring do not support the weight.
Old Jun 11, 2018 | 09:48 AM
6door74's Avatar
6door74
Less money i have to spend, sounds good! The lug nuts are the 60 degree acorn type.
Thank you
Old Aug 7, 2018 | 09:54 PM
maf226's Avatar
maf226
Centric rings
The rings do not support weight,but they certainly do center the wheel so you can torque the lug bolts.That is their purpose.You can get the from Discount Tire,or online at tire rack.com. They are not made because they are unnecessary.
Acorn nuts,and wheels can have wear that will give you balance fits. Get them and use them.
Old Aug 8, 2018 | 07:21 AM
baddad457's Avatar
baddad457
I need some with the old aluminum slots I have on my 96 E150. They do help distribute the weight as long as they fit snug. A lot of vehicles now have wheels that are hub centric to support the weight and center the wheels.
Old Aug 12, 2018 | 10:01 AM
gman97005's Avatar
gman97005
Originally Posted by 6door74
Hello all,
Thanks
https://www.uswheeladapters.com/
I purchased the custom plastic rings for $60/set, they reduced vibration and made a noticeable improvement in ride quality, money well spent.
Old Aug 18, 2018 | 01:31 AM
6door74's Avatar
6door74
Thanks. I just came back from a 1000+ mile round trip road trip and they felt good. There was no vibration but I may get the rings anyway.
kennyfzj80
Jan 31, 2018 06:33 PM
BruteFord
Jan 27, 2015 08:15 PM
raytasch
Oct 2, 2012 09:36 PM
EZLariat
2004 - 2008 F150
Jul 16, 2004 08:09 PM
3speed
Mar 21, 2004 09:35 PM
