fuel conditioner?
Old Jun 10, 2018 | 10:21 PM
fskubota's Avatar
fskubota
fuel conditioner?
Brand new owner, 2018 F450 6.7 diesel, 100.6 miles on it. I run fuel conditioner in every fuel tank on all my other trucks, What is the best one for the ford 6.7, to protect the fuel system and not harm the exhaust system????
Old Jun 11, 2018 | 07:02 AM
DeputyDiesel's Avatar
DeputyDiesel
Lots of threads on this topic and you’ll get a hundred different answers but overall most seem to run the ford recommended PM-22. I find it’s cheapest by the gallon at the dealer.
Old Jun 11, 2018 | 07:58 AM
troverman's Avatar
troverman
I'd second PM-22 (since it is a Ford product) but frankly its entirely unnecessary.
Old Jun 11, 2018 | 08:24 AM
Specs's Avatar
Specs
I've always felt (whether I used it or not) that fuel additives were slightly gimmicky. In some instances, like uncertain fuel grades, it is needed and useful; but overall it didn't do much. I could be wrong, but it's been my experience with it.
Old Jun 11, 2018 | 11:17 AM
wicked 2018's Avatar
wicked 2018
I use Opti Lube XPD each fill up and PRI-D fuel stabilizer on my 55 gal diesel drums
Old Jun 11, 2018 | 11:29 AM
roadpilot's Avatar
roadpilot
Motorcraft PM-22 here.
I also run the Motorcraft PM-23 Anti-Gel in the winter months.
If anybody is interested, Amazon has the 1 GALLON jugs of PM-23 for $12.63 and Prime members don't pay for shipping.
Yes, I said $12.63 per GALLON. I paid $58.95 for a gallon last fall.
Sure, it's summer, but as long as it's sealed, it shouldn't have problems lasting a few years. I know PowerService says their anti-gel products have an indefinite shelf life if unopened.
Old Jun 11, 2018 | 02:29 PM
mhoefer's Avatar
mhoefer
I keep anti gel PM22A in the truck in case, I keep PM22 in the truck in case I need it. I am buying from commercial card-locks only. Rarely do I use retail fuel. Most diesel is now 5% Bio diesel so lubricity issues are far less common. Adding it every tank seems like a non necessary expense to me. Other fuel additives can be used but you have to be sure they are not Water emulsifying. This allows the water to get through the filter and the water separator and do damage to the HPFP and down the line.(Emulsifying types of fuel additives typically showing alcohol such as methanol present)
Old Jun 11, 2018 | 03:37 PM
BillyE's Avatar
BillyE
I've used Redline, Stanadyne, PS silver, and a few others. The only one I've seen any difference with is Redline and that was slight.
Old Jun 18, 2018 | 02:43 PM
roadpilot's Avatar
roadpilot
The day after I ordered a couple of gallons for ~$12.xx each, the price went back up to ~$57.xx per gallon.
Old Jun 18, 2018 | 02:51 PM
LiquidSteam's Avatar
LiquidSteam
Not judging... just saying when comparing diesel to gas... never heard about having to run a fuel conditioner as well... what is the purpose of it? I’ve run many diesel generators but never owned a diesel truck. Thanks
Old Jun 18, 2018 | 03:25 PM
Chinookman's Avatar
Chinookman
So a fuel conditioner has many applications.
If you have a large tank for farm use, a Product to control algae, water etc is used.
Some provide lubricity due to the low sulfur fuel content.
So when speaking of adding a fuel additive please consider what it is you are trying to accomplish.
It will not give you a bazzillion horse power, nor half a bazillion mpgs, etc.
If injector lubricity is the goal there are some that will do that.
With a daily driver algae and water should not be an issue unless one uses a fuel station with low turn over.
Anyways, enough ramble hope I helped clear this up like mud!
86f350
27
Apr 22, 2009 10:35 PM
silver05fx4
Alternative Fuels, Hybrids & Mileage
Jun 20, 2008 11:56 PM
Chris60F100
Jul 26, 2005 10:05 PM
trakman
Sep 26, 2004 11:45 AM
Magnum1029
Apr 4, 2002 05:38 AM
