Help
Old Jun 8, 2018 | 06:02 PM
Janwilen's Avatar
Janwilen
Help
My 1990 E350 box truck has been parked for 6 years. I need to get it started and have maiintainence done. What should I do first?[/QUOTE]
Old Jun 8, 2018 | 06:09 PM
genscripter's Avatar
genscripter
Drain the tank. The old diesel in there is likely a jelly by now.
New filters, new oil, new diesel, and so on. Likely new batteries. Bring a spare voltage regulator (if the 1990 had a VR).
Purge the air from the lines: What to do if no Diesel Fuel is coming out of the Schroeder Valve on a 6.9 / 7.3 IDI ? IDI Online
Purge the air from the injector lines: How to Crack Injector Lines and Purge Air on a 6.9 / 7.3 IDI Diesel Engine ? IDI Online
Take it easy on the starter. crank for ten seconds, then let the starter rest for a few minutes between crankings.
As long as the engine is solid, the IP is decent, and the injectors are good, it should start right up. There isn't any computers or electronics to worry about on these old beasts, so its all a matter of getting fuel to the injectors.
For more Van IDI stuff, visit IDI Online ? DIY Repair for the 6.9 and 7.3 IDI Diesel Van (and other vehicles)
Old Jun 8, 2018 | 06:11 PM
genscripter
Also, bring some ATF just in case it runs funny after you get it started. ATF will help lube the IP and injectors.
Usually, people archive their old IDI's after something catastrophic debilitated the vehicle. You usually don't leave a good vehicle sitting around for 6 years. So I'd expect there to be something really wrong with it, which will complicate your process for awakening mighty kong.
Old Jun 8, 2018 | 06:58 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
After getting it running, I highly recommend changing the belts and hoses if your going to be driving it any distance at all. #1 cause of premature failure of our old fleet of these engines in our Ups trucks years ago were hoses, mainly heater hoses. If a hose splits on the hwy and your eye isn’t on the temp guage, it’s toast!! It’s cheap insurance.
bungeekord
Mar 29, 2016 06:02 PM
branden.w
Oct 31, 2009 12:34 PM
strange
General Diesel Discussion
Apr 8, 2007 10:56 PM
lwhitley
May 11, 2006 05:50 PM
tbirdrief
Jan 30, 2006 04:46 PM
