I picked up my first real project this weekend. However i found a high beam foot switch hanging from thd rh side of the dash and hooked to the blower resistor plug. I have air conditioning and a heater. Where are the resistors located? Behind the glovebox? Post image or description below .
I picked up my first real project this weekend. However i found a high beam foot switch hanging from the rh side of the dash and hooked to the blower resistor plug.
I have air conditioning and a heater. Where are the resistors located? Which type of A/C?
THREE different types of A/C:
Factory installed integral A/C is combined with the heater. The A/C controls are in the same panel as the heater controls.
Huge A/C evaporator case located at the right rear corner of the engine compartment.
There were also two types of dealer installed A/C:
Deluxe dealer A/C is combined w/the heater, has two switches located in the HUGE dash bezel that sweeps across the entire right side of the dash, covering up the glove box.
There is a separate 'hang-on' glove box bolted to the bottom of the dash.
Economy dealer A/C has a panel that contains two registers and two switches, panel fits into the dash to the left of the glove box.
