Heater problems
Old Jan 3, 2007 | 01:46 AM
sirkt's Avatar
sirkt
Red face Heater problems
The truck is a 1977 F-150.
The heater in the truck is not blowing. The heater works (I can put my hand under the dash and there is hot air coming out) but the blower doesn't come on. I have replaced the blower switch and the heater fuse. Anything else I should check before I replace the blower motor?
Old Jan 3, 2007 | 04:15 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check the blower resistor assy. Trace the circuits with a test light to avoid unnecessary $hotgun replacements.
Old Jan 3, 2007 | 09:52 AM
77460f150's Avatar
77460f150
The blower motor resistor is mounted in the heater box under the dash on the right side (pass) foot well. It looks like this (for a non-A/C truck): http://blueovaltruckparts.com/catalo...4373b70991d3d6
If you have a truck with A/C the resistor will be located under the hood on the right side in the A/C box and looks like this: https://www.ford-trucks.com/user_gal...135530&width=0 , https://www.ford-trucks.com/user_gal...135531&width=0 I'm not sure where to find a new one for a A/C truck, I have not seen one yet. This part get's rusted and nasty due to being mounted in the heater duct and getting damp. Remove and inspect, replace as needed. -Ed
Old Jan 3, 2007 | 01:17 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Your Heater blower should blow on high if the resistor is bypassed.
If it doesn't the Blower motor is suspect.
Does the truck have Factory A/C?
Old Jan 4, 2007 | 01:41 AM
sirkt's Avatar
sirkt
Sorry, Yes the truck does have factory A/C. I will try to bypass the resistor on Friday and get back to you all.
Old Jan 4, 2007 | 02:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation
D3TZ-19706-A .. Resistor, blower motor .. w/factory A/C
This resistor fits all 1973 thru 1979 F series trucks.
Try Green Sales in Cincinnati Ohio, if it is no longer available from FoMoCo.
_______________________________________
