Windshield washer issues (front and rear)
Old Jun 6, 2018 | 11:03 AM
96firephoenix's Avatar
96firephoenix
I already know what's wrong, I just don't know where to look in order to fix it.
So the first time I used the washer, it did great. Second time, it gave about 1/2 second of good spray, then fizzled to a stream, apparently running out. Dumped a full gallon into the reservoir, and got about a half-second of the fizzly stream and then nothing. I've noticed washer fluid leaking out around the passenger side hood hinge, and I can hear water bubbling sounds in the passenger A pillar when I'm trying to use the rear washer. Great, so I've either popped a fitting, or a hose (or multiple) has broken.
Can someone point me to which panels I need to remove in order to find the broken or disconnected hoses? From the couple pages I've found online, it looks like I should be looking under the passenger wiper cowl, and the passenger kick panel?
Old Jun 6, 2018 | 01:40 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Have you checked this sticky thread it might help
https://www.ford-trucks.com/forums/1...l#post15732762
Old Jun 6, 2018 | 02:54 PM
96firephoenix
I had not seen that. Thanks! it helps with the rear line at least... Now for someone to point me to a front squirter thread that I haven't found, lol.
Old Jun 6, 2018 | 03:36 PM
ShelbyHauler's Avatar
ShelbyHauler
Not sure if you have the same problem. Water was leaking under the bottle, turned out to be the pump. Put a new pump in. One of my front squirters did not spray well at all. Used a sewing needle to clear the nozzle, unhooked the rubber hose before the water bottle and used compressed air (blow gun with a rubber tip) to blow the crap out of the line. I did both the front nozzles and now have good working washer spray in the front. Make sure you disconnect the hose from the water bottle or you might blow a line someplace.
bigboylk
1978 - 1996 Big Bronco
Dec 23, 2017 03:48 PM
expy37at
Jun 5, 2014 08:28 AM
97ExpGuy
Feb 11, 2012 01:59 AM
Part-Timer
Oct 19, 2008 04:11 PM
XNrepair
Jun 11, 2008 03:02 PM
