Equalizer Hitch for TT with F350?
I towed my Jayco TT weight Dry 6400lbs. Loaded never over 8400lbs with an Equalizer setup on a 2014 F150 Ecoboost with the Max tow package. The equalizer was needed to help with the tongue weight.
I just bought a 2017 F350 Crewcab Diesel short bed with the 11,500 GVWR to tow this same trailer. I have read in Ford Literature that you may not need a weight distribution hitch.
My question is with that weight of trailer and a tongue weight of 1000lbs. do I need to use the Equalizer?
Thanks
Troy
Thanks
Troy
No need for a wdh on the new trucks. They’ll handle that small trailer with ease. 1000lb tongue weight will be just fine without it.
with a TT, though, the trailer may benefit from the sway control afforded by a WDH (if its built intot he WDH).
I recommend pulling it once without the bars attached and see how it feels. Then with the bars on and see if you can honestly feel the difference. Be sure to drop the hitch so the trailer sits flat, otherwise the trailer will wiggle and seem like it needs WDH sway control, when it fact it is just set up wrong.
Received 6,693 Likes
on
In one configuration of my trailer the tongue weight is a bit below 1,000 lbs. The ride is so much more confident with the WDH in use. For short trips in town I don't use the WDH but out on the highway it's always used. The WDH puts enough weight back on the front axle that I don't get the front feeling squirrely when other vehicles pass me. The WDH also eliminates any sway that the trailer may have.
I have the Andersen WDH with a 3" shank. I didn't want to fool around with the reducer sleeves. You probably have a 2.5" receiver so only one reducer sleeve is needed.
Thanks
Troy
Thanks
Troy
ezduzit01
1999 to 2016 Super Duty
06-15-2014 08:14 AM
mcanik
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
23
06-15-2006 11:25 PM
keith w
10-16-2004 12:21 AM
