I would love to replace the rubber mat but mine has the big hump with the driveline park brake which when I last looked was not available, at least with my efforts. Needs a dash pad but I could not find one for a 66 F 350. Also would love to buy correct shifter boot but again not available. If any one knows where these could brought let me know please.
Dash pad is available aftermarket. Dennis (Daniel?) Carpenter carries it and shows it is in stock. They might be having "Just Dashes" make them. Same pad was used on F100-1000, which includes the F350 in there.
Lots of trucks had the taller cover over the transmission area. My F250 4x4 trucks are both the same as your F350, but without the parking brake handle there - instead the transfer case lever is closer to the driver than the shift lever for the transmission. The mats had the lightning bolt and gear in each footwell.
There were two big templates that came in the box with the floor mat to indicate where to cut it for various models.
The first template was for the clutch rod and other things in the drivers footwell.
The second template was for the items in the hump area.
The pic of the tranny looks like while restoring, could you post a pic after you completed the restoaration, I would like to see the tranny support if that is possible, many thanks.
