Bad Head Gasket??? Maybe
Old Sep 20, 2003 | 10:32 AM
klassik's Avatar
klassik
Okay here is a question from a super novice and a woman too. So bear with me.
I recently purchased a late 80's F250 6.9 diesel w/a Bank turbo, automatic. Use it to haul a two horse trailer. I have only had gas engine trucks previously so I know very little about diesels.
A friend tells me I may have a bad head gasket. Now for the question - How do you tell. I don't see any leaks, the truck runs like a top. Nobody found anything wrong when I had it checked out but what should I be looking for just in case.
Thanks for your help.
Old Sep 20, 2003 | 12:16 PM
nogo73's Avatar
nogo73
first off let me say
welcome to the world of diesels
there are a number of signs one is testing your oil
another is take the cap off the radiator and see If you got a lot of air bubbles coming up
another is oil in the antifreeze (most of the time this is a bad oil cooler)
or antifreeze seeping out of the head
hopefully this helps
Old Sep 20, 2003 | 01:19 PM
nogo73's Avatar
nogo73
also to prevent a head gasket failure clean or replace CDR valve every 6000 miles
Old Sep 21, 2003 | 04:00 AM
Saigon's Avatar
Saigon
Hi,
Welcome to the big-rig world !
You can also do a compression check, it will tell you if the engine is in good shape, rings, valves & gaskets.
Magic
1990-f250
Mar 13, 2021 04:44 PM
lemonshindig
31
Sep 30, 2010 01:01 PM
pnj442
Jul 23, 2010 02:23 PM
skirk55
Jan 23, 2010 05:22 AM
Ikester
Nov 25, 2006 08:04 PM
