Get a pressure gauge and check the system pressure. No one is going to be able to tell you what the problem is without that data, so you might as well do it.
Even a cheap charging kit will have a gauge with it that will give static pressure and tell you if there is a charge in the system. You can look up static pressures by temperature online and see what the low side should be for the temperature outside.
If you want to check it on the cheap, get one of those recharge can that has the gauge on it. Then you can test the pressure and add if needed at the same time without having to dish out $100+ for a halfway decent set of gauges.
OK. I bought a can of R-134 Freon with a gauge. Started the truck & let it warm up. Turned the AC & fan to max. Attached the R134 & got a reading of only 15 PSI. Added R134 until I got a reading of about 40 PSI. The compressor began to cycle on/off. About 1 second on & 3.5 seconds off. Added enough Freon to get to about 45 PSI & removed the can. The compressor continued to cycle on/off.
But..............................
Still no cooling. AC blows as warm as pre Freon charge.
But I now know the pressure switch is OK. Do I have a bad compressor? What else could it be?
You probably need more refrigerant. If you only had 15 psi to start with, it was essentially empty. There should be a sticker under the hood that gives the total charge. You can guess at it and hope you get lucky or you can fix the leak and then charge it accurately by weight.
I added more r134. no change in symptoms.
Per the gauge on the can, it reads about 25-30psi when the compressor cycles on & about 45psi when the compressor cycles off.
sor cycles off.
What do you mean, "no change"? The thing's cycling now, before it wouldn't engage the clutch per your report. How much refrigerant did you add?
The pressures appear normal on the surface but lack context. Those are the typical -pressures for when the low pressure switch cycles but, we don't know either the ambient, the load or the cycling rate.
Did you check the temperature of the evaporator inlet and outlet tubes while the system was cycling?
Still needs more refrigerant. A front only system takes almost 3 cans, more if you also have rear air.
