96 7.3. Bad IDM right ??
Old Jun 1, 2018 | 11:00 PM
Dutter 2's Avatar
Dutter 2
So this morning my truck wouldn’t start, glow plugs are are working and I barrowed a scanner from work and my icp pressure is 1000 psi cranking and 54% ipr duty cycle. But the scanner doesn’t do function test so I checked the IDM and got 12v going to it and back probed the 2 put put power wires #23 and #24 And only got 4.5 v out of one and 0 v on the other wire while cranking. Got the same number when I back probed the connectors at the valve cover. So bad IDM correct ??
Old Jun 2, 2018 | 12:13 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
A number of conditions have to be met before the injectors are fired. HPOP pressure at the ICP, RPM and Sync with the CPS to name a few. I'm not convinced that you have proven the IDM bad. Did you shake it and see if it has water in it? Did you check the connectors at the valve covers for burned pins?
The guys over in the powerstroke forum know this cold. I would be over there if I were you. Did you get their no-start flow chart?
https://www.ford-trucks.com/forums/forum170/
Old Jun 2, 2018 | 12:18 AM
Dutter 2's Avatar
Dutter 2
I am getting rpm signal and my icp pressure is plenty good and ipr is good. And the connectors are good cus I’v had them off not too long ago
Old Jun 2, 2018 | 12:21 AM
HardScrabble
No Start Flowchart:
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
You didn't mention fuel pressure?
Old Jun 2, 2018 | 06:26 AM
HardScrabble
The buzz test would be good if your scanner will do it. You can watch the pulse width too, I think the pulse width changes when the injectors are firing. You can pull a valve cover and see if the injectors are squirting a little oil when they fire.
4. Injectors bad; Injectors with high miles on them can fail to operate cold. If correct PW displays on cranking you can remove the valve cover and watch the oil spill discharge, every injector should discharge oil when pulsed by the IDM during cranking. If no pulse of oil then the injector isn't activating and injecting fuel into the cylinders. Running several buzz tests cold will sometimes free up the injectors. This is typical in a high mileage situation with inadequate engine oil changes.
https://oregonfuelinjection.com/serv...gnostics/#1994
Check these: If the battery voltage is low the IDM won't fire. Maybe the same for 5v too.
Old Jun 2, 2018 | 07:51 PM
Dutter 2's Avatar
Dutter 2
I
my fuel pressure gauge dosnt fit my truck but when I push the Schrader valve while cranking is shoots right out so thats atleast enough pressure to feed the pump. And if it were injector issues I’d be loosing a cylinder or two not all 8. I took off the IDM-120 and found that someone has already messed with it. All siliconed together by a 6th grader and missing all the screws for the circuit board
Old Jun 2, 2018 | 09:57 PM
Lead Head's Avatar
Lead Head
Doesn't sound like your IDM is too happy then.
Old Jun 2, 2018 | 10:00 PM
Dutter 2's Avatar
Dutter 2
Nope that’s what I’m thinking. And I’m getting no voltage on one bank and only 4.5 volts on the other. Should be 48 volts
Old Jun 3, 2018 | 06:01 AM
HardScrabble
6.0 is forty something volts. The 7.3 is 100 some odd volts.
Check me on all of this. I want to learn it but you know how it is... So many toys, so little time.
Injector info was posted in support of IDM questions. When does the system ask the IDM to fire? You have to know you are meeting these conditions before you can say the IDM is not working. Maybe it's not being asked to work. Maybe there is a clear cut test for the IDM. Closest thing I know of is a buzz test. If you throw IDM codes on a buzz test it might tell you something. The injectors spurting oil shows they are being fired by the IDM.
Old Jun 3, 2018 | 11:27 AM
Dutter 2's Avatar
Dutter 2
You may be right on the voltage spec it I thought it was 48 volts but I work on many other diesels so I may have gotten the spec wrong. But the IDM needs signal from the pcm to fire and the pcm won’t give that command until it sees at least 500 psi from the icp and a high enough rpm speed from the cmp as well as have good strong battery’s.
Old Jun 3, 2018 | 11:33 AM
Dutter 2's Avatar
Dutter 2
And I would really like to buzz test but my scanner sucks and doesn’t do function test
Old Jun 3, 2018 | 12:38 PM
HardScrabble
Somewhere I saw mention of a signal that excites the IDM but I can't for life of me remember what it was. And just like you said, I could be thinking of another system. The signal from the cam sensor is an input. The other one, the one I'm not sure of, I think is from the computer to the IDM.
Old Jun 3, 2018 | 01:09 PM
HardScrabble
https://www.ford-trucks.com/forums/8...stuck-low.html
This might be what I was thinking of. Maybe it doesn't excite the IDM.
Know anyone with a good IDM you can try?
Pin 96 CID cylinder identification
Pin 95 FDCS Fuel Delivery Control Signal 650-3600rpm
Pin 48 EF Electronic Feedback digital electronic frequency
Those are the lines I was thinking of. That and $1 will get you a cup of coffee. That was from the coffee table book.
http://www.powerstrokediesel.com/index/419
Old Jun 3, 2018 | 02:04 PM
Dutter 2's Avatar
Dutter 2
No I tried asking around for a IDM and the crappy part is I use to have a extra one then sold it. But I’m going to order a new one online and on Monday I’m going to see if I can barrow a better scanner. The shop one sucks so most guys buy there own where I work
Old Jun 3, 2018 | 03:21 PM
HardScrabble
Forscan is good for these trucks. Documentation is spotty but the Forscan forum gives you direct access to the software developers.
