Sponsored by: Real Truck
04 psd 6.0 missing / skipping after some work
Old Jun 1, 2018 | 03:22 PM
jovol's Avatar
jovol
i just installed an IPR gen3 delete, new ipr valve, and blue spring kit, and with it all back together the engine is missing at 2000rpm+. In gear or out of gear the missing doesn’t start til then. Starts up just fine cold or hot. Also did a oil change with new filter and fuel filters and coolant flush.
Any advice on how to start narrowing down the issue? Fuel pressure? Injector? Identifying which cylinder is missing?
Here’s a video I took of the symptom:
thanks,
john
Old Jun 2, 2018 | 01:15 PM
jovol's Avatar
jovol
Bumppp, any advice? I went ahead and reseated all my injector connectors, ficm connections, and reverted my fuel pressure spring to the original one to make sure that didn't cause anything weird. I did notice the fuel line oring in my blue-spring kit was too large and was smooshed, so I put back in the original one which was still fine.
I'm hoping I didn't damage an injector in all this work. When I first put everything back together, I found out one of the bolt holes that the oem oil cooler water jacket uses was punched through (previous owner must have used too long a bolt?). With the bolt in there, I'm guessing it wasn't leaking, but the IPR egr delete wasn't using that hole, so when I went to crank it there was a massive oil leak. There was probably a total of ~2min off and on of cranking that was done as I was trying to find the oil leak. Could that have hurt the injectors? After I took it all apart I looked down the bolt hole and found the puncture. I fill it up with some black RTV silicone, chopped the bolt to a shorter length, and tightened it back in there. Fortunately the bolt head doesn't interfere with the IPR egr delete.
I'm on the verge of buying autoenginuity, but would love to not shell out another $350. I might put back in my old IPR valve as well just to see... I changed it out because my truck was intermittently losing power/stalling with white smoke out the tailpipe. I have a coolant pressure gauge hooked up and it hasn't shown any overpressurization, so I'm fairly certain it's not a HG issue.
Old Jun 2, 2018 | 01:57 PM
jovol's Avatar
jovol
Didn’t realize there was a 6.0 specific sub forum. Gonna restart with a thread tgere..
jovol
Jan 21, 2019 12:00 PM
str8shot1
Mar 13, 2015 08:05 AM
lcmains1
Aug 3, 2013 06:35 AM
04WVPSD
Jun 8, 2013 02:14 PM
w6bauer
Apr 29, 2012 03:18 PM
