Modular V10 (6.8l)
tranny leaking
Old Sep 20, 2003 | 07:29 AM
LNH68's Avatar
LNH68
tranny leaking
looked under truck this morning has been to dealer 4 times for tranny leak every time they fix it lasts about two weeks then starts leaking again very small amount but still bugs the hell outta me. leaks around the bolts on the pan just on the front. any ideas that i could tell dealer cause i think they gave up.
I know they are goin to say its just a small weep not really what you call a leak and tell me to stop lookin under it
Old Sep 20, 2003 | 07:32 AM
HeavyAssault's Avatar
HeavyAssault
tranny leaking
Kinda sound like you can start a buy back option. I bet they find the problem. Try and look above where the drips are it may be higher on the bell housing.
Old Sep 20, 2003 | 08:32 AM
bobbyboy's Avatar
bobbyboy
tranny leaking
LNH68, had the same problem when i first bought my 02 CC4x4-V10, just droplets around a couple of the bolt heads and a little in the lip, took back 3 xs, was not dripping on the ground just seemed to form there. Third time new Tranny! NO more problem.
Old Sep 20, 2003 | 10:04 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
tranny leaking
I'm not sure about the 4R100, but on my '96 T-bird/'97 Cougar 4.6L cars, the tranny pan "gasket" is REUSABLE.
Quick edit: the above trannies are 4R70w's.
It's really a rubber gasket with metal reinforcing it inside.
I wonder if the gasket is bad, and because it's "reusable", they don't really change it? Just check torque on the bolts and leave it?
Or, the bolt hole was drilled too deep and it's leaking around the bolt threads.
Either way, there is an easy fix - actually REPLACE the gasket and then use RTV on the bolt threads.
Sounds like a typical Ford Dealer. Don't use their brains, just do what the computer says.
ak
Old Sep 20, 2003 | 11:13 AM
LNH68's Avatar
LNH68
tranny leaking
Yep looked under it and on bottom of pan says reusable gasket, i'm gonna take it back to dealer again they can fix it. Thanks for the info.
ycis
Jan 28, 2014 02:44 PM
hdman6
Dec 1, 2011 03:08 PM
900rr
Modular V10 (6.8l)
Nov 20, 2007 05:32 PM
DL
Jul 21, 2005 06:46 PM
HP junkie
Jun 29, 2003 02:09 PM
