Please help decoding my vin. 1970 Ford C610
1970 ford low tilt C610. I need help decoding this vin please. C61DVH50680. Any other info would be great. I really need engine size. My truck keeps overheating when I haul grain. I know I need a new thermostat for sure.
No such thing as a C610. If you look closely at the first 3 digits of the VIN, it's C61 .. D = the 4th digit of the VIN is the engine code.
Plus, you asked this question in the wrong forum, this forum is for 1973/79, your C600 is a 1970. Please ask further questions in the LARGE TRUCK forum.
C61 = C600 Tilt Cab (gas).
D = 330 2V Heavy Duty FT engine.
V = Kentucky Truck Assembly Plant.
H50680 = 1970.
111" Wheelbase.
JM: J = Rangoon Red / M = Wimbledon White
C611 = C600 Tilt Cab (gas), 22,000 lbs. GVWR
A28: A2 = Light Gray Crush Vinyl & Gray Twill Stripe Woven Plastic / 8 = 91B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
F3M:
F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Axle Capacity.
M = Ford 7,000 lbs. Capacity Front Axle with Power Steering.
22,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3800 RPM
545412:
54 = Omaha NE Ford District Sales Office, where the original selling dealer ordered the truck from.
5412 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
