Superlift Radius Arms
Old May 29, 2018 | 06:06 PM
mikeym1's Avatar
mikeym1
superlift states their radius arms are for lifts 4-8" in height. is there anything wrong with running them at 3.5" of lift? would they be a direct replacement of the oem arms, nothing else needed?
Old May 29, 2018 | 06:45 PM
Tricon's Avatar
Tricon
They would work fine with 3.5" of lift. Should just be bolt on.
Old May 29, 2018 | 09:26 PM
brandontolentino's Avatar
brandontolentino
They should work fine, as Tricon stated. You just may have a tad more caster than is recommended by the factory. In all likelihood, it will probably be unnoticeable.
Old May 30, 2018 | 05:23 PM
mikeym1's Avatar
mikeym1
is there any advantage to swapping them out? ive added a 1" spacer to the carli 2.5", and have achieved a perfectly level stance i was looking for, but have noticed very slightly more bump steer. i already have the fox stabilizer in factory location. i was at 4.3-4.5* caster prior to the 1" spacer, i will check tomorrow to see where we are now.
HD991994F150
Apr 23, 2013 06:49 PM
cjbronco
1978 - 1996 Big Bronco
Oct 25, 2005 12:44 PM
94BlackF150
Mar 2, 2004 04:30 PM
bronco351
Oct 14, 2002 10:20 PM
mafman
Jan 24, 2001 09:55 AM
