Thanks
Old Feb 6, 2005 | 08:22 PM
jakemb's Avatar
jakemb
Thanks
Thanks for the responce on the problem with the fuel in the oil.Truck is parked untill the injector o-rings get looked at.Been going threw all the posts here and can't find anybody else with this problem. how common is this.Seems like I'm the only post with this happening.Also noticed the last time i drove the truck was loosing oil pressure,probably due to the fuel in the oil.
Thanks again for the responce.
Jake
Old Feb 7, 2005 | 06:48 AM
ltfox's Avatar
ltfox
I remeber the tread you posted and injector orings don't make sense to me. Your high pressure oil system runs at around 3000psi while the fuel system is around 50psi. You would have oil in the fuel, not fuel in the oil. Am I thinking right, that had me confused.
