Will I need to replace the rear shocks when adding a 5 inch block and removing the stock 2.5..i have a 4 inch spacer kit form super lifts... It says nothing but the shocks just seem short travel wise now... And it's alittle bouncy in the rear now...
Thanks..
Post a pic of the truck after the 4" superlift if you can.
The superlift kits I see all come with shocks and springs. What's the link to the kit you used?
I was thinking about using the 3.5" sst readylift kit on my 2018 f250 6.2L gas, even though they say it won't work - the offroad shops I've talked to said the exhaust just needs to be slightly modified where it gets close to the front driveshaft on the 6.2s.
I do have a set of rear shock extenders .. I just bought all 4 bilstein shocks.. Rears are the only issue as the front spacer on this kit raises everything... including the shock mount..
Think I can get away with this for now?
I think it sits well with the 4 inch kit.. .might move to a 6 but not sure. Not ready to get new tires and the rest that goes with it since I just got all this stuff..
