Sponsored by: Real Truck
No Cruise Control
Old May 26, 2018 | 03:22 PM
Scott McCoy's Avatar
Scott McCoy
No Cruise Control
Hi all,
When I bought my 08 F250 with a 6.4l diesel the cruise didn't work. I searched this site and a few other looking for reasons why. I have checked everything I read as a possible cause but with no luck. The dash light does not come on when the key is turn on so I'm thinking that it may have been turned off in the computer. Is this a possibility and if so is the dealer the only one that can access the computer?
Thanks in advance
Old May 26, 2018 | 10:51 PM
Fefanatic's Avatar
Fefanatic
Could be something as simple as a switch. You should have a on/off switch and a set/accel/resume switches. When turned on the dash light should be amber. Once set it would turn green. The cruise needs to sense the truck is in drive, speed around 30mph, and the brakes are not applied. If either of those sensors are not working then cruise won't work. My guess? It will be the on/off switch on steering wheel or the clockspring behind the steering wheel. Good luck...
Old May 27, 2018 | 10:07 AM
Scott McCoy
I considered the clockspring as I do occasionally have issues with my steering wheel volume controls but because I didn't have the dash light turn on when key on and that I have a A/M radio I started leaning toward it being turned off in the computer.
Ronnief150man
44
Oct 25, 2021 02:44 PM
millejas
Apr 22, 2018 04:58 PM
ang210
Transit Connect
Feb 1, 2016 07:19 AM
88bronco351
2009 - 2014 F150
May 19, 2013 01:54 PM
pjw2565
1983 - 2012 Ranger & B-Series
21
Nov 2, 2005 04:23 PM
