Water bypass on radiator
I have a 92 F150 XLT, 302 cu in engine, 4WD, automatic transmission. I am looking for this steel tube part .387 inch diameter, part number F2TZ8555A. It sits on top of the radiator and goes from the throttle body to the radiator cap. It is 24 inches from bracket to bracket. Anybody know where I can find this part. Tried several Ford dealers and this part is discontinued... Thanks!
Larry
Larry
I replaced that exact hose with standard rubber heater hose, have had no problem with it so far, going 4+ years.
That's a Good Idea!
Larry
Thanks Hardscrabble
The following users liked this post:
Larry
That was an awesome fab job. I ended up using 3/8 brake line to make a line on my '95.
One thing to NOTE about using the rubber plugs for the radiator. When the rubber plug dry rots and begins cracking, get it swapped for a new one. 13 psi doesn't sound like much, but it will **** a HOT stream of coolant over all your accessories when it FAILS and the belt starts slipping and then it's a mess.....It happens...I know. Thats why I fab'd a line from the radiator to the TB.
Fab Job
Larry
I guess it's safe to assume that the equivalent part (my shop manual calls it part number 8548) for a California spec 1996 F250 460 V8 4x2 with E40D transmission is also impossible to buy new.
Anyone know if the water bypass tube off other engines is equivalent? I'm guessing not, given the part number that NumberDummy provided for OP has 8555 in it.
Haven't seen a 460 in the pick n pull for a long time...
LARIAT 85
04-02-2011 06:14 AM
GreatNorthWoods
01-24-2003 05:22 PM
