That is the updated fitting. I found the same thing on my truck after purchasing an STC fitting kit, so if anyone out there wants a Motorcraft STC fitting I have one available.
Be careful back there, I remember a long thread about what happens when you drop an object in that hole. Make sure you get that area clean before the cover goes back on.
I cleaned it up good before removing the cover,didn't want to take any chances of dirt or other objects getting into engine.last thing I want is an oil leak in This area.
My IPR went bad and I decided to check this while I was working on truck.
Originally Posted by navistarnut
Di you air test it to confirm it's leaking there?
Not yet that is on the list for tomorrow,I'm in no rush and want to make sure everything is exactly right before I button this thing back up
My bad, I thought you had suspected a leak at the STC.......rare but they do go bad, but from what I've read it's the o ring most often.
