UPPER STEERING COLUMN SLOP!
Old May 24, 2018 | 06:05 AM
BIG ZILLA's Avatar
BIG ZILLA
Let me get this out of the way... 91 F350 CC LB 4x4 7.3 IDI E4OD, NO TILT COLUMN
This truck was owned by 3 fatboys in a row (myself included). Apparently we each found the need to pull on the steering wheel to get our fat asses up into the truck. Now there is a bunch of play towards the driver door in the column. The rod that engages the starter is also broken, hence the momentary switch added to the dash. It doesn't bother me too much but now the AC only comes on if I wiggle the wheel while holding the key slightly forward of "run". The lock cylinder was replaced .
Pinched wire?
Old May 24, 2018 | 02:27 PM
tjc transport's Avatar
tjc transport
i ain't rite
there are no wires in the top of the column that would effect the AC only wires in the column above the brake pedal are the horn and blinker wires.
my bet is the upper bearing is gone causing the ignition actuator rod to put the ignition switch in a partial off position.
Old May 24, 2018 | 02:38 PM
BIG ZILLA's Avatar
BIG ZILLA
Thanks, It's about time I took on that job anyway. It keeps me from putting the tranny in tow mode and the turn signals don't work either. I just discovered that since the op.
Old May 25, 2018 | 02:14 PM
tjc transport
i ain't rite
to be honest, if that was my truck i would be looking in junkyards for a replacement column.
Old May 28, 2018 | 05:54 AM
BIG ZILLA's Avatar
BIG ZILLA
Since I can't find parts anywhere I'm betting that is my ONLY option. I do know someone local parting out 2 '88 F350 duallys w/ 7.3 IDI.
Old May 28, 2018 | 06:27 AM
tjc transport
i ain't rite
same column. as a bonus, he may even have a tilt column for you to install.
Old May 28, 2018 | 06:51 AM
BIG ZILLA's Avatar
BIG ZILLA
He does, One of the trucks has a running 7.3 and good body and running gear. I'm thinking of making him an offer for the whole thing and putting it in the road. Like I need another project, LOL
Old May 28, 2018 | 07:27 AM
tjc transport
i ain't rite
mehhh. you can never have too many projects.
especially if one of them is a running F-350 IDI dually!!!
Old May 28, 2018 | 08:52 AM
BIG ZILLA's Avatar
BIG ZILLA
perhaps you are my kind of people. maybe you would appreciate the ULTIMATE REDNECK HOOD ORNAMENT.
mmhoward
Jan 4, 2011 03:32 PM
hotrod351
May 29, 2010 08:16 PM
MY68F250
Apr 2, 2008 09:46 PM
briansrapier
Feb 24, 2006 11:12 AM
