460 ????
Old May 23, 2018 | 09:11 PM
Twinibeam1's Avatar
Twinibeam1
460 ????
Hello all
I am wanting to put a 460 in my 1966 F100 it is a 3 speed on the tree with overdrive, does anybody know were I could get a bell housing that will work with this sit up ?
Thank you
Old May 23, 2018 | 10:45 PM
James_Western_Canada's Avatar
Better start buying up three speeds NOW, as I expect their life behind a 460 will be SHORT
Old May 24, 2018 | 06:10 AM
66v8baby's Avatar
66v8baby
You can use a bell housing from a 77-79 351M or 400 truck as they share the same big block bell housing. You might want to consider a better xmission though. I would suggest the NV4500 from a 2WD Dodge truck. You can get a rebuilt one with an upgraded 1 3/8" input shaft that will allow you to use a 12" clutch disc from a 428CJ or Boss 429. Or you can use an 11" GM clutch disc with the stock (1 1/4" IIRC) input shaft. It's a massive xmission though and will require several mods to make it work.
Chris Guthro
42
Jul 21, 2014 10:01 PM
explosionrc
Engine Swaps
May 12, 2011 04:53 PM
jrwhitey_2000
Jan 9, 2009 07:51 PM
dstruble
Mar 27, 2008 01:05 PM
olfordsnstone
Engine Swaps
Nov 22, 2004 09:20 PM
