hi there im new and was wondering if any one could tell me what these vin codes are im most interested in the body and axel gears thanx alot w.b. 114 - color v - model f100- body 66a- trans a- axel 12 the vin# is f10j6370486 its a 63 i was told and i just got it.its all original condition. thax alot
F 10-2WD F100, j- 223/ 114 Hp @ 3600 RPM,Color- Academy Blue,
66A- Standard Cab W/Stileside bed, Trans A- 3Spd. manual light duty, Axel 12-3.89 Mfg date Jan, 1963
F11CR481991
F11- 61/66 4WD F100
C-292CID 2V CARB 135HP@3800RPM
R- ASSM. PLANT- SAN JOSE
481991- MFG. NOV. 1963
120- MAY BE THE W.B. NOT SURE. PLATE SHOULD SAY
M- CORINTHIAN WHITE
F- 4 SPD. MANUAL TRANS
110- ALSO 4WD
F81 DON'T KNOW
F12- DON'T KNOW
9600- I THINK THIS IS 5600 WHICH WOULD BE THE GVW. YOU NEED TO CHECK
510160- DONT KNOW, MAY BE A PRODUCTION DATE?
