4x4 conversion?
Old May 22, 2018 | 11:48 PM
slacker1965's Avatar
slacker1965
4x4 conversion?
Anybody done one?
'06 single cab 2wd currently 168k engine & trans work fine....
had no luck sellin.... Kinda need 4wd & can't afford 2trucks
I am told frames are same & it's mostly bolt on....
Like to know if I can use my trans or if main shaft length is different.....
tyvm in advance
kevin
tried search on this crappy old iPad...please don't fry me
Old May 23, 2018 | 06:40 AM
brandonrr's Avatar
brandonrr
I've gone down that road before. I had a 6.0 that already had studs, oil cooler, BPD egr cooler etc and only 160k miles. I looked into converting it to 4wd.
I came to the conclusion that unless you find a donor truck for the 4x4 parts and you are able to do some heavy wrenching, it just wasn't worth it. A shop that was willing to convert it wanted 4 grand for labor alone if I supplied the parts truck. Other shops wouldn't even entertain the idea.
Old May 23, 2018 | 07:08 AM
navistarnut's Avatar
navistarnut
I think it boils down to how much time, and commitment, you are willing to put forward.....and as mentioned finding the parts cheap enough.
It's going to end up being a research project of sorts.
That said there are guys that have stuffed a 6.0 in a Crown Vic, so if you wanted to bad enough I'm sure it can be done.
Old May 24, 2018 | 12:10 PM
slacker1965
yeah I got a guy that can get me a donor truck drivetrain/ft suspension minus engine for 600-1000..... I can do the mech & fab work.... electrical not as good.... trans no.... hence the mainshaft question.....
if I could sell my 2wd for decent coin then it would be no issue..... sofar no takers & 4wds are 4-7k more than my ride in similar shape......
since people lift cabs off to bulletprooof & beds are simple, maybe I'm missing something?
Old May 26, 2018 | 06:44 AM
slacker1965
any trans people on here? still trying to figure if the trans are same save for tailshaft/trans case.....
Old May 26, 2018 | 07:50 AM
mattdoc88's Avatar
mattdoc88
Not an answer, but find a 4wd VIN on a site like Auto trader and use it to look for parts at Auto Nation White Bear lake and look for a replacement transmission. Then see if they come up with the same part number for your 2wd VIN.
Old May 26, 2018 | 01:14 PM
jsm180's Avatar
jsm180
PM Mark Kovalsky he is the expert on Ford transmissions.
grec-o-face
Apr 17, 2013 05:02 PM
akamacgyver
Nov 12, 2011 01:11 PM
NY_FORD_GUY
May 26, 2011 09:49 PM
Redneck'n
Feb 13, 2006 09:41 PM
gopedoligist
Mar 5, 2004 11:34 PM
