5th Wheel Towing Question
Old Jun 4, 2018 | 08:34 PM
00t444e's Avatar
00t444e
A 41' 5th wheel is a big trailer for a SRW, it isn't just about load capacity a DRW truck will also be much more stable when towing a big high wind resistant load like that. You could probably get by with a SRW truck but a dually would handle it better and be much safer, and they aren't that bad to daily drive once you get used to them. The new F450s with the wide track front have a better turning radius than my F250 does.
Old Jun 7, 2018 | 05:10 PM
lawnspecialties's Avatar
lawnspecialties
Being a present F450 owner, my opinion is you'll be absolutely fine with an F350 SRW. If that's what you want, I'd get it. You may want air bags to level things out but other than that, it should do well.
Also, don't be worried if the rear end is a 3.55. My 2015 F350 SRW had the 3.55 and although I was concerned, it was a great set-up if you're getting the 6.7.
hondapro
All Things Towing
19
Sep 25, 2017 08:58 AM
PrinceValium
Oct 12, 2016 10:33 PM
JFMDAD_1
All Things Towing
18
May 6, 2015 02:08 PM
PrinceValium
2009 - 2014 F150
13
Aug 14, 2013 10:45 AM
A_Flyfisher
Dec 13, 2007 10:07 PM
