any power steering pro's?
Old Nov 19, 2019 | 12:07 PM
1TonBasecamp's Avatar
1TonBasecamp
Hey tfarr. Welcome!
Being a 2-wheel drive, I'm not as familiar so will leave it to the others. Even though I don't know the answer to your question yet, I'm sure it's been done so someone will have some insight.
In the meantime, hope you and your son get lots of enjoyment out of the truck.
Paul
Old Nov 19, 2019 | 06:30 PM
SDD74's Avatar
SDD74
Originally Posted by tfarr
Hi Bill, Im new today to the site so please bear with me. Inherited a 1975 F150, 360 2WD that im looking to install power assist PS for my 16yr old son. Having trouble as local mechanics here in Santa Fe NM haven't done this before. Any thoughts on how and where to get parts for conversion, thanks T Farr
to swap the manual to power steering you will need the pump, pump brackets, gear box and the steering column. Your best bet would be to find a parts truck with all the components needed
Old Nov 19, 2019 | 10:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If your F150 is 2WD, you do not want Power Assist P/S because it was only used with 4WD
You need to find a 1973/76 F100, 1975/76 F150 w/a 360 or 390 engine and remove all the P/S related parts.
P/S pump and gearbox, pressure and return hoses, any related pulleys and etc.
This is Ford/Saginaw P/S, the P/S pump has a steel reservoir, the P/S pressure hose threads onto the pump.
Old Nov 21, 2019 | 09:31 AM
tfarr's Avatar
tfarr
Thanks Bill and All, Appreciate the info and guidance! Will proceed as above
Ford1959F100
Jul 15, 2019 07:23 PM
Spyderjohn
Feb 17, 2012 05:55 AM
hondadriver4life
Oct 15, 2007 03:46 PM
wtppower
Apr 3, 2005 03:04 PM
