I'm the one needing help now
2006 F250 ,,,no programmer,basically stock execpt for Egr delete .
truck shut down while driving today.I have torque pro app.
Below is key on readings
I have checked for codes and the only one I'm getting is B 1357 .Not sure if that related to my problem
Key on
image below is while cranking.shouldnt my Hpop be reading much higher than this
Key on
Bismic,,,Icp and Ipr are same cranking or KOEO
Also Haven't checked the STC Fitting but I thought 06 and later models didnt have on
something else ,,In first photo taken when truck quit IPR value was 83.9.After sitting for a while it is 14.7
05 and up have the failure prone STC fitting.
If you don't see the dash oil pressure gauge come up when cranking, you may have a base oil pressure issue. Remove the oil filter cap and have someone crank while you watch to see if it fills up (and how fast it fills up). The best way to crank is with the starter solenoid wire disconnected and jumpered to the battery positive terminal (passenger side) - with the ignition key in the off position. Or you can pull the FICM relay and crank w/ the key (but that still powers the glow plugs).
The IPR will start out at 14.7 or there abouts until you try to start. Then the duty cycle will increase (closing the IPR valve) until you get sufficient high pressure oil pressure. It (the IPR duty cycle) peaks out at 84% (max duty cycle).
I removed oil filter the morning .when I cranked engine it immediately began filling the reservoir.at rate it was filling it would probably run it over in just a few seconds cranking.
Probably the most common place that a foreign object comes from (when that the IPR screen is torn), is the HPOP. Sounds like you might have a bad one.
It is always a good idea to do an air test after the repairs and before putting the valve covers back on. The best way for the air test is with the IPR tool (IMO).
You can rig up your own w. the cheap amazon fitting below.
The 1300 psig ICP value (w/ the ICP unplugged) was just a default value due to the sensor being unplugged. You actually have low pressure, so it would not start.
https://www.amazon.com/TamerX-Test-Fitting-Powerstroke-2003-2010/dp/B071G1SSWW/ref=sr_1_2?s=automotive&ie=UTF8&qid=1527374460&sr=1-2&keywords=TAMERX+ipr+air+test+tool
or get it w/ the hose and air fitting
https://www.amazon.com/Powerstroke-High-Pressure-System-SPECIAL/dp/B0771QN34P/ref=sr_1_7?ie=UTF8&qid=1527374157&sr=8-7&keywords=ipr+air+test+tool
I made a pressure test fitting from my old IPR fitting.When I connected air pressure I had a massive leak under drivers side valve pan.
I pulled the oil rail and stand pipes and couldn't find anything wrong.
Went ahead and pulled injectors and think I found some bad o-rings on the number 4 and 6 cylinder.
Going to replace all tomorrow and see if than fixes my problem
Two of the Injectors had white O-rings and the other two the white looks like it has worn off.
