Ohio Chapter Join Chapter, Leader: RUNVS
Cleveland area? I need a hand with my 5.4 2v's plugs/coils
Old 05-22-2018, 01:23 PM
Travis S's Avatar
Travis S
Travis S is offline
https://www.ford-trucks.com/forums/1...s-on-a-2v.html
First plug came out okay (#1, passenger side front plug), but the new coil doesn't want to seat properly on a new plug. I'm a bit concerned that I might be missing something. Is there anyone in the Cleveland area with a 2v that's gone through the process before and can lend their wisdom so I do the coils/plugs correctly? I've watched just about every Youtube video out there on the subject, compared old and new coils/plugs and it's still not adding up.
thanks,
Travis
Old 05-22-2018, 09:56 PM
Delta1166's Avatar
Delta1166
Delta1166 is offline
Are you on the West Side of CLE? If so, maybe call Mark @ North Shore Performance...440-331-9860. He's done a couple of 5.4 plug & C-O-P replacements.
Old 05-23-2018, 01:30 PM
Travis S's Avatar
Travis S
Travis S is offline
about 20 miles SE of Cleveland and my truck is currently in the driveway, dead in the water
Old 05-24-2018, 08:08 PM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
The 2 valve plugs will come out ok. There not the ones that stick in that is the 3 valve problems with the 2 valve is spitting them out. On the coils there is a spring in them so it dont feel like there seated right. I put them on and tighten the 8mm bolt down and it should be good to go.
Old 06-02-2018, 04:49 PM
Travis S's Avatar
Travis S
Travis S is offline
Yes, I know they come out without any fuss.
Yes, they come out fine. It's just a matter of getting to them. Anyone in the area with firsthand experience able to lend a hand?
Old 06-03-2018, 10:04 AM
5_labsownus's Avatar
5_labsownus
5_labsownus is offline
Received 1,558 Likes on 1,453 Posts
Watch this Part 1 Passenger side
Drivers side
The good part about these videos, is he tells what tools to use.
Old 07-14-2018, 05:24 PM
Travis S's Avatar
Travis S
Travis S is offline
After a lot of stuff going on, I revisited the tune-up. #2, #3 and #4 coils are out now, I'm stuck on plug #4. It's like there's ZERO ROOM to get tools in place. What's the magic trick for it? Or better yet, show me the trick here in person and I got $25 for you.
#5-8 seem like a breeze compared to this. This makes me miss my RX-7 with how simple and straightforward it is,
Old 07-15-2018, 09:10 PM
5_labsownus
Go back and watch the videos, as I remember he goes over the tools that worked.
Old 07-20-2018, 07:33 AM
Travis S's Avatar
Travis S
Travis S is offline
Can Dr Spark Plug make a house call?
Bad news. #3 was repaired with a threaded insert before and it tore in half on removing the plug (rusted onto the plug, distorted from overtorque by Hestons in Lancaster). Now a plug won't thread back in. With all of the experience of FTE, and the amazing goodwill of the community, is there anyone in the Cleveland area that can help me out ASAP by making a house call to fix this for cheap? I don't like asking for help, but I'm completely dead in the water right now and unable to work as a result. Because of that, I'm damn near flat broke too :/
I just need to be able to put a plug in there, nothing fancy. Not asking for a handout, a hand UP. Bring a flash drive and I'll make it WELL worth your time/effort.
Old 07-29-2018, 10:11 AM
5_labsownus
Best to go to some of the smaller local shops and talk with them and see if they have or know someone to meet your needs. A new thread insert can be put in again but I do suggest someone that has preformed this on damaged and previously repaired hole.
Old 08-23-2018, 06:04 PM
Travis S's Avatar
Travis S
Travis S is offline
It got fixed. Insert came out on the plug, was a M16x1.5 thread one. No damage to the cylinder head. Found the same kind at Oreilly auto parts for $15. Simple, cheap fix
Old 08-23-2018, 08:00 PM
5_labsownus
Glad to hear that. If it all comes out then as you found a new insert will work.
Skatermike24
1999 to 2016 Super Duty
05-09-2017 12:12 AM
dentfxr
Modular V8 (4.6L, 5.4L)
08-10-2013 06:51 PM
Denola
16
01-02-2013 06:22 PM
jcee
07-08-2010 08:17 AM
brooks35
10-25-2003 12:12 PM
Quick Reply: Cleveland area? I need a hand with my 5.4 2v's plugs/coils
