Need your help with axles
Old May 21, 2018 | 09:50 PM
Fyrwlkr's Avatar
Fyrwlkr
I have a 9 inch Ford without a tag so don't know what year. Pulled it apart for differential work. found 30 inch long 28 spline axle shafts but they have a 5.5 lug pattern. the seal race is scored so would like to replace the shafts but can't find any with that bolt pattern unless I get custom made from Currie. I found a list of 5.5 bolt patterns but then they are not 9 inch rear ends. Has anyone used the "cut to length" shafts?
Old May 21, 2018 | 10:11 PM
BlueOvalRage's Avatar
BlueOvalRage
A 5.5” pattern on equal length 30” long shafts for a 9” Ford sounds like a ‘57-‘72 1/2 ton truck axle. In lieu of replacing the shafts, you might look into Speedi-Sleeves. They are thin, precision ground stainless steel sleeves that go over the seal journal to restore the surface and allow reuse of the shaft with the original seal size. I’ve used them before with great success.
Old May 22, 2018 | 10:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pulled it apart for differential work, found 30 inch long 28 spline axle shafts but they have a 5.5 lug pattern.
The seal race is scored so would like to replace the shafts but can't find any with that bolt pattern unless I get custom made from Currie.
Where the hell are you looking, under a rug?
ALL 1957/79 F100; 1975/79 F150 have 5 lug wheels on a 5.50" bolt circle.
1957/67 F100 have 11" x 1 3/4" rear brakes; 1968/72 F100 have 11" x 2 1/4" rear brakes.
Notice in the pic below how Ford measures axle shafts.
B7TZ-4234-A (replaced B7C-4234-A) .. 28 Spline Axle Shaft - R/L is the same // A length: 29 11/16" = 1957/67 F100.
C8TZ-4234-A .. 28 Spline Axle Shaft - R/L is the same / A length: 29 15/16" = 1968/72 F100.
Old Jun 3, 2018 | 07:24 PM
nsboyd1210's Avatar
nsboyd1210
Here is the link to the Speedi-Sleeve manual/catalog if interested.
http://www.industrialbearings.com.au...1338271826.pdf
Nelson
artscott61
20
Jun 5, 2017 03:51 PM
nordvik72
Jan 23, 2010 11:20 AM
62 red truck
Jul 26, 2005 05:31 PM
Drool Monkey
Oct 17, 2004 08:06 AM
1970Custom
Oct 13, 2004 12:39 PM
