Sponsored by: Kumho
Ford 9 Inch
Old Oct 11, 2004 | 08:01 PM
1970Custom's Avatar
1970Custom
Ford 9 Inch
Hey everyone, what's the difference between the 9" in a 81' F-100 and a 70' F-100? I know that the axle splines and bolt patterns are different, but what else, also i've also heard that the frame of the 81' is three inches wider, why I'm asking is because I'm using the front end of a 1989 lincoln for my 70 and i know that the lug pattern is the same with the 81 and the Lincoln.
Thanks for the help
Eric
Old Oct 12, 2004 | 12:20 AM
rebocardo's Avatar
rebocardo
The axle bearings are different and the 81 probably has the seal on the axle shaft instead of inside the axle tube like the 1970.
Old Oct 13, 2004 | 12:39 PM
murphco's Avatar
murphco
the older 9's have butt welded axle tubes and 28 spline axles.the bolt pattern should be the same 5 on 5.5 with the execption of some later f-100's that had ranger bolt pattern.the later 9's have axle tubes that go inside the center portion of the housing and are much stronger,they also have 31 spline axles and larger axle bearings that are oil lubricated.the width is aprox 64 inches.
