If you have an automatic trans in it, it could be a torque converter lockup switch. I have heard of those being used to aid in engine braking.
If auto, I'm putting my money on this.
Based on the RPM band you stated, I do believe you're hearing the exhaust note that the IDI's make when in the higher RPM band. As previously stated, it wouldn't be the best option to throw actual Jakes on the 6.9s due to their higher compression numbers.
Is what you're hearing sound about like this video?
this gives a bit better example of what the exhaust note sounds like, only this guy is trying to blow his trans by pulling it down into second gear from drive to get the sound.
From what I have been reading, it sounds like downshifting into manual 2nd is a legitimate way to engine brake the truck. I'm not sure about long-term effects but even TransGo prescribes it in their manual for testing after the Tugger kit is installed. Even Mark confirmed it. See post #16 https://www.ford-trucks.com/forums/1...d-today-4.html
Not sure I am ready to try it on my truck, though.
Right, there's no way Jacobs Engine Brake Co. could dream up and design a Jake brake on an IDI. First, there's no injector rocker arms to trigger each 8 cylinder head mounted solenoid assembly to pop off each exhaust valve at TDC compression stroke. Second, if it was possible to design one similar to Jake brakes on class 8 diesels there'd probably about $250,000 in R&D. Then probably about $3000+ cost to the customer. There's a LOT of parts and switches to an engine brake.
Still, there are guys who throw an exhaust brake on their IDI and wonder why the valves floated and got bent.
Don't know anything about the valves floating, but a Jake brake has nothing at all in common with an exhaust brake. Totally different mechanism, a Jake brake has nothing to do with the exhaust system other than momentarily pressing on the each cylinder's exhaust rocker arm at TDC compression stroke releasing compression. Then with no compression and both valves closed that's where you get the powerful engine breaking. Rather than a firing power stroke, it's more or less turned into a "suction" stroke as the piston comes down.
Yeah, that's a different system than what I was thinking.
Hey guys I've been off line for a while I appreciate all the input you have all given ( especially the videos) that is what it sounds like so you guys are probably right on it being the compression. My truck is a five speed so that is a no on the transmission idea. As for the wires and the switch I still don't know but its not for the brake box because that is there and the harness for it is intact and far from those wires. I will be pulling the valve covers in the future but I have other projects that take priority at the moment when I pull them I let you know what I find.
I am thinking that whatever the missing piece under my dash was it did have to do with towing. Like I previously stated the truck had been set up for long haul goose neck (probably hotshot)
i wonder if the switch and light were for a glow plug controller bypass because a previous owner was not smart enough to figure out how the controller worked?
If you're still looking for a Jake Brake, it won't be hiding under the valve covers. First, the valve covers would be sitting about 2" 2 1/2" above and off the heads and bolted to a cast iron housing that's the same diameter as the valve cover that in turn is bolted to the valve cover bolt holes. Otherwise the assembly wouldn't fit under the covers. Here's a pic of one from a NTC Cummins, two cylinders per head: https://www.google.com/imgres?imgurl...act=mrc&uact=8
I was just following a suggestion and figured the engine could probably benefit from the gaskets being changed. I also figured there something not normal visable if there was. But I won't dig in any deep just to prove or disprove a theory
