2016 Rear End
2016 Rear End
So I've been on a business trip for almost a week and while on this trip my wife calls and said that the Expy has a vibration while turning. Doesn't matter the speed, acceleration or deceleration, just always happens when she turns. My over the phone diagnosis was a CV joint since that's the only thing I could think of at the time. Got home today and drove it myself to try and figure it out. Well it's coming from the rear end. It's also got kind of a slight drone while its vibration. Only thing I can think of is the clutch pack in the rear end is sticking. There is no leak so it's got oil in the diff. Is there anything else it could be?
Limited slip unit is probably chattering. Should be a warranty/courtesy thing. Probably does not need a lube change, just a slug of limited slip additive, but if you want to change to synthetic rear end lube this might be a good time (not sure if Ford uses full synthetic from the factory).
George
George
