Valve Stem back order
Old May 20, 2018 | 09:02 AM
eryoung's Avatar
eryoung
Well had another valve stem leak, called dealer, he said her would order another. didn't hear from him in 4 days so I gave him a call yesterday morning. He said he can't find any anywhere. There back ordered now. He doesn't know when they will come in. Ugh
Old May 20, 2018 | 04:04 PM
lariatbob's Avatar
lariatbob
Where are these leaking? Valve core or around the rim hole? I have pressure loss on all 6 tires. Getting tired of filling every week. I have tightened the cores and extenders but no change.
Old May 20, 2018 | 04:25 PM
wb6anp's Avatar
wb6anp
Look for "dually valves" they will require demounting the tires, but may help, also wont need extenders. I had them on my motorhome.
Dually valve kits for Motor-homes, Busses and 6-wheeled chassis
Maybe call them and ask, the ones for the class C's may work.
Old May 20, 2018 | 04:48 PM
wrvond's Avatar
wrvond
My local dealer had them in stock. If you want to call and ask if they have any more, it's John Sang Ford in Gallipolis, Ohio.
They are leaking at the hole. Corrosion is evident in all cases, however, since the inner wheels are steel, few (if any) people have had a leak problem with the inner wheels, just the outside rear and fronts. I've had all four replaced with rubber valve stems under warranty, which cured the problem.
Old May 20, 2018 | 04:58 PM
zeroo's Avatar
zeroo
Ford just approved 4 rims for me after trying the rubber stems in my original rims that leaked because of the steel stem corrosion. Dealers ordering new rubber. This was Friday, so I will check with them tomorrow to see if they are back ordered for him. Ford crapped the bed with the steel valve stems.
sail2xs
Dec 17, 2025 09:37 AM
tortue71
Apr 25, 2021 05:37 PM
eryoung
May 15, 2020 11:50 AM
Shoester
Apr 10, 2019 12:16 PM
wmancuso
2004 - 2008 F150
Nov 27, 2009 12:35 PM
