EGR restrictor plate
Old Sep 19, 2003 | 03:32 PM
RedneckF-150's Avatar
RedneckF-150
Angry EGR restrictor plate
I have a 1981 F-150 300 I-6 4x4. It bucks like crazy after about 3 minuites at 55 and will buck in every gear after that. I have taken off the vacuum line and plugged it, and put on a restrictor plate with about a 1/4 inch hole. Should it be smaller or what? I have tried several sizes, but this is the smallest. Would blocking the valve completely help? It is carbuerated so I have no codes to clear. Can anyone help? Please, this problem is getting very annoying. I cannot even make a quick run to the store without the bucking.
Old Sep 19, 2003 | 05:47 PM
mantta's Avatar
mantta
On my 88, I blocked it off completely with good results.
Old Sep 20, 2003 | 05:44 PM
bigbadjs's Avatar
bigbadjs
I thought the restrictor plate mod was only meant for the fuel injected models.
Old Sep 22, 2003 | 07:10 PM
RedneckF-150
I found the problem. After tearing half the engine apart, trying different size restrictor plates, idle settings, plug gap, and having two professional mechanics say it was the EGR valve, I put a new set of plugs and wires and the bucking was gone. Which just says, don't jump to conclusions.
